Thanks a bunch
Edited by AustinStage1, 22 January 2009 - 12:13 AM.
Posted 22 January 2009 - 12:12 AM
Posted 22 January 2009 - 07:48 AM
Posted 22 January 2009 - 08:47 AM
Posted 22 January 2009 - 09:05 AM
Posted 22 January 2009 - 09:09 AM
there are some good deals on ebay for leccy ignition.
A lucas gold coil is a good all rounder.
Posted 22 January 2009 - 09:22 AM
Posted 22 January 2009 - 10:28 AM
Please do asearch if you require information regarding electronic ignition, Dan posted up a very comprehensive post about this yesterday.
Britpart do a leccy 'nition kit for under £10 that is the cheap and works.
Posted 22 January 2009 - 11:24 AM
Posted 22 January 2009 - 11:34 AM
The Lucas Gold coil is not remotely an all rounder, there's no such thing as one coil that's good for everything. The Lucas Gold Sports Coil is very strictly for 12v ignition, if you fit it to a ballasted car (all Minis built after 1984 are ballasted) it won't work well at all. If you use it with an aftermarket ignition module designed for use with a standard coil (Magnetronic for example) it will damage the module.
If you want to know what the best coil would be for your car, you have to give a bit more information than '998 with a Stage 1 kit'. What year was it built for one thing?
Posted 22 January 2009 - 12:16 PM
Edited by Dan, 22 January 2009 - 12:18 PM.
Posted 22 January 2009 - 12:18 PM
Someone linked to this kit yesterday and the problem that occured to us all was the rotor arm. The rotor arm is a service part of a dizzy and can need repacing every few years but in this kit the trigger wheel and rotor arm appear to be a single unit. You would have to buy another unit from the seller in order to replace the rotor arm, he may sell just the arm as a spare but I can't find a listing for it. Also I don't believe anyone makes a Lucas rotor arm as well as Lucas do, other ignition kits have a seperate trigger that allows you to keep a standard rotor arm.
I doubt this kit would work well with a ballast but that doesn't affect you and your '78 car. What would affect you is the Gold coil. This is just the type of kit that tends to be made for standard coils and is designed to get the best out of a standard coil. It doesn't say in the listing whether it's designed for a Sports Coil or not but it would be safer to assume it isn't. You don't need a Sports Coil with electronic ignition anyway, most electronic systems can get a lot more output than a set of points can from a standard coil. An increase from 3,000 to 25,000 volts is not unusual. Most electronic ignition manufacturers produce their own sports type coils that work with their systems rather than designing the system to work with commonly available coils like Lucas Gold.
I'd be interested to know about the 'high quality silicon' that the kit comes with! What is it? What's it for?
Posted 22 January 2009 - 12:27 PM
With the ignitor there are 30,000 to 35,000 volts available. Normal range on (OK) standard systems range from 26,000 to 27,000 volts. The 'ignitor' can be converted to a high energy system by the installation of a high energy coil and silicon HT leads. The Aldon 'Flame Thrower' coil or Lucas sports coil have both proven to be very compatible with the ignitors.
Edited by lrostoke, 22 January 2009 - 12:32 PM.
Posted 22 January 2009 - 12:43 PM
On the point of fitting Gold coils to ballasted ignition systems it can be done, you just remove the 2 wires from the positive coil connection (tape them up) and run a new 12v feed from white wire on the fuse box.
Fitted it to my sisters 998 ballasted ignition, and works a treat
but I did fit a Gold sports coil to my 998 fitted with an Aldon Ignitor
Posted 22 January 2009 - 12:44 PM
Posted 22 January 2009 - 12:52 PM
System is designed for use with most point-type coils, optimal performance achieved when used with our Flame-Thrower® 40,000 volt coil.
would 8-v fall into the range of a ballast system, not sure what normal voltage is on the ballast ??Operating Voltage: 8-V to 16-V DC
Flame Thrower Coil for 4/6 cylinder used mainly for road or fast road use. Not suitable for race use. THESE COILS ARE NOT SUITABLE FOR IGNITOR 2 APPLICATIONS.
Edited by lrostoke, 22 January 2009 - 01:32 PM.
