1990
Right I'm a little confused (story of my life) and I could do with a definite answer one way or the other.
Anyway for years now I've been using NGK BPR6ES Spark Plugs (generally from Halfords as their reasonably priced and their guide book tells me to use the copper core type with either '071' or '710' stamped on the cardboard packaging) on my 1990 Mainstream Mini Cooper (I've changed them every 12,000 miles to ensure I get no problems), but I just wonder now if I've been using the correct type of plug?
My Mini came with electronic ignition as standard and so I assume the 'R' (in BPR6ES) stands for resister and is required for radio suppression when electronic ignition is used?
But looking at my original owner's handbook: -
Rover originally recommended spark plug type 'GSP 4362' (probably Unipart Surefire plugs?) and so what's confusing me is the pdf shop list on Somerford Minis claims that these plugs were of the non-suppressed type and that the NGK alternative is BP6ES? However, Somerford claims that these are suitable for 1959-1986 Mini models only (look up Spark Plugs items 30-32): -
http://www.somerford...tter-Models.pdf
But they list the suppressed type for 1990-94 carb models as 'GSP4482' (under original fitment) and then NGK 'BPR6ES' as the alternative.
So who is right? Did Rover quote the wrong type of spark plugs on that general data guide?
When looking up Spark Plugs under fuel injection models, Somerford Minis quotes: -
http://www.somerford...cs-Injectio.pdf
Somerford Mini advices that cars fitted with electronic ignition and fuel injection should always use suppressed spark plugs (otherwise known as resister plugs), which significantly cut down the amount of interference generated by the ignition system. The correct operation of engine electronic control units and electronic ignition modules could otherwise be affected.
So I assume that 'BPR6ES' is the correct plug for me after all?
Edited by taffy1967, 18 January 2009 - 08:29 PM.
