Exhaust Notes
41 replies to this topic
#1 chappy
chappy
  • 1,253 posts
Posted 17 January 2009 - 09:43 PM
Okay, so i have this idea of all you people recording a video to get an idea of exhaust notes, for people considering what exhausts to buy.
unfortunately i have no video of mine at the moment, but if you think its a good idea then post up a link to your video and list what your exhaust is...
if you don't think its a good idea, then... well.... never mind.
sam
#2 MGMT
MGMT
  • 1,109 posts
Posted 17 January 2009 - 09:45 PM
Yeh sounds like an alright idea
problem is that the sound quality on most video recording equipment is rubbish!
#3 pariahcreative
pariahcreative
  • 109 posts
  • Local Club: frome minis
Posted 17 January 2009 - 09:46 PM
Not a bad idea.
You would have to specify more than just the exhaust though.
Air filters, carb type and engine size alsoplay a massive part in the sound.
But a good idea.
Rob
#4 koomey
koomey
  • 224 posts
  • Local Club: not yet
Posted 17 January 2009 - 09:49 PM
sounds good , i fitted an rc40 backbox and k & n filter recently and my spi sounds awesome, really mean ! will try to get a vid sorted
#5 chappy
chappy
  • 1,253 posts
Posted 17 January 2009 - 10:17 PM
yes thats a fair point, but its just to give an idea.
Not a bad idea.
But a good idea.
Rob
also a good point, so,
clip of exhaust note, and list of specs. and exhaust type.
#6 baker_boy
baker_boy
  • 971 posts
  • Local Club: "wot no brakes"
Ill try and get a vid up. iv got a maniflow system with a k&n element filter and a stainless fletcher 3" backbox, sounds gorgeous :D
#7 chappy
chappy
  • 1,253 posts
Posted 17 January 2009 - 10:25 PM
the only problem i have is i have no idea what my exhaust is at all,
came with it when brought it,
i'll look through the details for things brought, by the prev. owner, if not i'll take some pics and i'm sure someone on here will be able to tell me..
sam
#8 Burnard
Burnard
  • 3,350 posts
Posted 17 January 2009 - 10:35 PM
Lil tip on the sound quality: place the camera 3-5 meters away from the car, still preferably behind it. The sound may be slightly quieter, but the quality should be allot better than most of these vids with people who put them right underneath the exaust.
Chris
#9 Ethel
  • 25,865 posts
Posted 17 January 2009 - 10:50 PM
It would be a novel resource for creative peeps too. You'd probably get the best results recording directly on to a laptop.
#10 Asphalt
Asphalt
  • 2,173 posts
Posted 17 January 2009 - 10:53 PM
Maybe this helps a bit. It's in german, but engine specs should be understandable (K&N is the same in german :o)
http://www.minischra...section=podcast
Most exhausts sound different under load, thought :D
Edited by Asphalt, 17 January 2009 - 10:54 PM.
#11 sweetser
sweetser
  • 3,995 posts
Posted 18 January 2009 - 12:28 AM
Best on i have of mine, and its pretty cr*p >_<
Standard 998 mayfair, dont have a clue what the exhaust is.
If my mini was running i would get a better one, but its not so i cant :w00t:
Cheers Luke.
#12 Sir Cheat
Sir Cheat
  • 1,171 posts
Posted 18 January 2009 - 12:33 AM
Are your re painting your gate black, Sweetser? lol
Sounds good, Did you have choke on?
Edited by Sir Cheat, 18 January 2009 - 12:35 AM.
#13 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 18 January 2009 - 09:11 AM
Topic moved to the 'MINI VIDEO' section. Please use this area for all your Exhaust videos.
#14 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 18 January 2009 - 05:19 PM
thought i would make a video of my 1380 engine sound , couldent help myself :proud: , nothing special exhaust wise , just a stage one exhaust i think . hopefully getting a large bore twin dtm.
engine spec is
A-series block bored to 73.6mm , cross honed and had new cam bearings fitted and reamed. 11 stud fitment.
Standard crank, balanced.
1275 con rods
AE Hepolite Triumph pistons with a 10cc dish
Steel centre main strap
Glacier Shell Bearings, Vandervell mains and big ends bearings
Minisport CA4 road/rally cam , same grind as the supersprint 544 camshaft
Piper cam followers
Mini Sport Oil Pump Spider Drive
Mini Sport Lightened Duplex Timing Gear & Chain Set
High Capacity Water Pump
MG METRO 1275cc A+ 12G940 BIG VALVE HEAD 36mm inlet valves and 31mm exhaust valves, 11 stud, Extra Strong Single Valves. Ports slightly polished.
Med 1.5 Roller Tip Rockers
All new pushrods
Verto clutch set up
New clutch kit
Heavy duty clutch plate
Lightened and balanced Verto flywheel
New seals and gaskets all around
Performance Head gasket Mini - Turbo 1275/1400
1275 A+ Gearbox with 3.4 final drive
Weber dcoe 40
http://uk.youtube.co...h?v=_JRA9bnUH6o
makes a nice noise =] camera dosent do it justis
ash
#15 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 18 January 2009 - 05:24 PM
engine spec is
1275 con rods
Piper cam followers
All new pushrods
Verto clutch set up
New clutch kit
Weber dcoe 40
ash
I hope my 1380 sounds as good as that. Brilliant.
