Another Electric Mini
#76
Posted 23 October 2012 - 07:51 AM
#77
Posted 23 October 2012 - 11:30 AM
Might be worth put a few design patents in for when we run out of fuel and all us mini owners want to go electric ;).
#78
Posted 23 October 2012 - 11:55 AM
Thank you!Quite possibly, one of the coolest builds on the forum.
Nah, nothing new here, it's just repackaging stuff I've picked up from the online DIY community. Besides, it's too late, it's already out in the public domainMight be worth put a few design patents in for when we run out of fuel and all us mini owners want to go electric ;).
#79
Posted 23 October 2012 - 12:53 PM
You know you can get an electrically heated windscreen from Minispares?
#80
Posted 23 October 2012 - 01:18 PM
Thanks, but at least I won't have to drive with the windows wound down all year to avoid asphyxiation from the leaking exhaustGreat work, but I bet it still drips oil on your drive
No I didn't, does the MOT accept that as an alternative to a demister?You know you can get an electrically heated windscreen from Minispares?
#81
Posted 23 October 2012 - 03:25 PM
Surely you will need some sort of heater in there though anyway..? Gas heater?
#82
Posted 23 October 2012 - 04:04 PM
It produces a reasonable amount of heat at 72V and should work pretty well when I bump the voltage up.
#83
Posted 23 October 2012 - 05:50 PM
Edited by momini, 23 October 2012 - 06:00 PM.
#84
Posted 25 October 2012 - 07:32 AM
#85
Posted 25 October 2012 - 12:33 PM
#86
Posted 06 November 2012 - 11:42 AM
It was only a couple of miles to the testing station, but enough to confirm that she needs more power. It's nothing a few more dilithium crystals can't fix though. The motors are capable of a lot more, the bottleneck right now is in the battery pack and controller. She should be pretty nippy when get round to fitting the rest of the pack and a higher voltage controller. I'm aiming for 0.4g acceleration from 0-60 mph.
The batteries are secured in an angle iron frame in the rear seat space, with a square-section restraint bar to stop them joining me in the front. I've installed the chargers in the space either side of the pack.
Instrumentation is minimal right now. The speedo is the original tachometer, taking pulses from an inductive proximity sensor on the tail shaft of one of the motors. I worked out the speed at given rpm and then printed off a new dial for the tach.
I'm planning to fit a ZEVA fuel gauge, designed for electric conversions. This measures the state of charge of the battery pack and displays it on the original fuel gauge. It also monitors the battery current and displays this on the original tachometer (I have a spare).
I also want to wire up a pair of analogue ammeters, one for each motor, just to check how they are sharing current under different conditions.
I haven't done any cosmetic work yet, as you can tell. It looks as if the Mini is going rusty, but that's just glue from the old carpet. Fibre glass doesn't rust as far as I know
#87
Posted 07 November 2012 - 10:30 AM
#88
Posted 08 November 2012 - 07:52 PM
#89
Posted 09 November 2012 - 12:48 AM
momini: Heating issues, in the UK, in November... no, not been a problem yet :) Just the opposite, I nipped out to Asda first thing this morning when the batteries were a bit cold and I really noticed the drop in power because the voltage sags a lot more under load. That's mostly a problem because I'm using such a small pack.
Not really expecting any overheating problems even when it gets warmer as the cylindrical cells I'm using have plenty of ventilation space between them and they're rated for rapid discharge. I'm more concerned about insulating the cells to keep them warm in the winter. Overheating becomes more of a problem in racing, where you're pushing cells beyond their recommended discharge rates.
#90
Posted 09 November 2012 - 09:54 AM
