Alternative Fuels For Diesel Space Heaters?
9 replies to this topic
#1 edi57
edi57
  • 821 posts
Posted 15 January 2009 - 09:05 PM
Is it ok to use used engine oil in a diesel space heater?
If so I'm guessing I should probably filter it before putting it in the heater? If anyone can think of a suitable and simple filtering method that wouldn't get messy...that would also be handy.
#2 mattdc2r
mattdc2r
  • 1,296 posts
  • Local Club: Not yet!
Posted 15 January 2009 - 10:01 PM
Wouldn't have thought so mate, it's far too thick for a start. probably knaker your pump before it got anywhere near the burner unit.
#3 mike.
mike.
  • 6,176 posts
Posted 15 January 2009 - 10:04 PM
Why not just use veg oil?
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 15 January 2009 - 10:05 PM
Or red diesel?
#5 edi57
edi57
  • 821 posts
How about an oil/diesel mix?
The space heater is going to cost me enough... I just want to find a way of staying warm cheaply!
Edited by edi57, 15 January 2009 - 10:06 PM.
#6 RetroRay
RetroRay
  • 836 posts
Posted 15 January 2009 - 10:08 PM
Uncle ran his old escort diesel van on chip/veg oil never had a problem believe it or not
#7 mattdc2r
mattdc2r
  • 1,296 posts
Posted 15 January 2009 - 10:49 PM
Diesel engines work differently to the space heaters. Obviously the engine in compression ignition, where as the space heater has a burner unit. In the burner unit of the space heater are 2 electrodes that are set up to ignite the diesel as it is sprayed in atomised form from the spray nozzle. Used engine oil/ vegetable oil etc will be to thick in my opinion, so you'll have problems obtaining the relevant pressure from the pump. We use Dantherm space heaters, which require fuel pressure of around 10 bar or 147psi. I dare say there is a way of using the oil by adding additives etc, but I'm no scientist.
I think if you were to attempt it, you'd just end up with a horrible mess in the burner unit and probably knackered pump, also the inline filters wouldn't be able to flow enough and they'd just get blocked.
Edited by mattdc2r, 15 January 2009 - 10:50 PM.
#8 minivanman
minivanman
  • 3,454 posts
Posted 15 January 2009 - 11:43 PM
We have a waste oil burner in the garage, its totally different to a space heater. You have to get it up to temperature with paraffin, then the pump kicks in and drips oil into the burner. Gets seriously hot!
#9 edi57
edi57
  • 821 posts
Posted 16 January 2009 - 05:49 PM
Thanks for all the comments. I think you've saved me from ruining a space heater.
#10 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 16 January 2009 - 05:53 PM
Most diesel space heaters should run on paraffin too
