Braided Brake Lines, Are They Worth It?
Posted 11 January 2009 - 08:19 PM
there is a package on eBay for £50 with everything in it that seems pretty good.
it includes:
discs
blackstuff pads
pad fitting kit
braided goodridge front lines
and caliper seal kits
linky
what are peoples thoughts?
cheers
adam
Guest_Zenob1_*
Posted 11 January 2009 - 08:46 PM
Matt
Posted 11 January 2009 - 08:54 PM
Not to mention its cheaper and i get discount too
Guest_Zenob1_*
Posted 11 January 2009 - 09:26 PM
I only changed mine because they had seized and failed MOT.
Matt
Posted 11 January 2009 - 11:59 PM
Posted 12 January 2009 - 08:40 AM
Edited by robtheplod, 12 January 2009 - 08:43 AM.
Posted 12 January 2009 - 08:59 AM
quick question ... can you clamp a braided hose like you can a rubber one???
No.
Most braided lines have a PTFE inner which is a stiff plastic pipe and cannot be crushed without damaging it.
Posted 12 January 2009 - 09:13 AM
Posted 12 January 2009 - 09:45 AM
if doing the fronts, worth doing the rears as well?
Posted 12 January 2009 - 10:08 AM
i realy need to put an order in asap, and need to know whether to add them to the list?
Posted 12 January 2009 - 10:36 AM
anyone?
that set looks good. get it for the front, if you havnt got disks at the back dont convert, just get new shoes drums and fitting kit for the back. when changing over the hoses watch out for the union pipe it conects onat the subframe. these can seize and are easily rounded off.
sat
Posted 12 January 2009 - 10:43 AM
adam
