Project 'lesbian Rose'
347 replies to this topic
#46 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 02 March 2009 - 11:24 PM
likin that alot with coilovers always have 2 finger space between the wheel and the arch i find even with fat buggers in the back still go over bumps at 80
#47 evil ewok
evil ewok
  • 354 posts
  • Local Club: A's of Herts
Posted 02 March 2009 - 11:36 PM
no need to worry about people in the back...chopped out the seat lol only going to have a drivers seat most of the time aswell. dont want any excess weight :owned:
#48 evil ewok
evil ewok
  • 354 posts
Posted 04 March 2009 - 08:15 PM
have run into a slight problem....rolling the car about have notice the tyres are rubbing on the coils :lol: so will need to spacer them, which also means i will need ANOTHER set of arches to keep the wheels covered lol
whats wider than the group 5 racing flares? miglias?
#49 evil ewok
evil ewok
  • 354 posts
Posted 05 March 2009 - 08:16 PM
found a few pics that i forgot about.
the main part of the zcars dash, was a really good fit. only needed minor adjustment to fit, most adjustment was straightening up the door seams lol
my digidash mounted in the dash pod. just need to work out what type of switches to use? original rocker type,toggles, or some small round rockers?
also took this yesterday to show how much space is between the tyre and rear quarter. had to remove the fg arches as the tyres are rubbing on them :teehee:
i was looking at the beam axle earlier and i may have found another small issue. it has a bar going across at the bottom (think its strengthening or anti roll bar?) but it goes in front of the exhaust tunnel so the exhaust may have to go lower. it would then most likely scrap the floor lots as the car will be rather low :dontgetit:
#50 Jackman
Jackman
  • 4,053 posts
Posted 06 March 2009 - 02:57 PM
Are you running lowered coilovers or standard hight?
#51 evil ewok
evil ewok
  • 354 posts
Posted 06 March 2009 - 07:08 PM
standard as far as i know.
this is the package i got at bingley:
http://www.minispare...amp;prod_id=582
they are just on their lowest setting
#52 Jackman
Jackman
  • 4,053 posts
Posted 06 March 2009 - 08:21 PM
Thank you, thats a great help.
Keep up with the good work :P Also, have you thought about tubbing the rear arches (It will look even higher at the back with no arches but gives you more travel when its that low)
Edited by Jackman, 06 March 2009 - 08:21 PM.
#53 evil ewok
evil ewok
  • 354 posts
Posted 06 March 2009 - 08:37 PM
Keep up with the good work =] Also, have you thought about tubbing the rear arches (It will look even higher at the back with no arches but gives you more travel when its that low)
no problem. i have considered tubbing the arches but i dont have the skills to do it, and cant really afford to have someone else do the work :P
it will have arches on when finished, just need some wider ones as wheels will have to be spaced to stop them rubbing on the coils. looking at either miglias or group 7's?
what do people think?
http://www.minispare...d...&prod_id=21
http://www.minispare...amp;prod_id=240
#54 evil ewok
evil ewok
  • 354 posts
Posted 07 March 2009 - 11:43 AM
i'm not very happy at teh moment. just tried to adjust the camber of the rear wheels, to stop them rubbingon the coils so i can move the car about until i get spacers, and beam axle has bent! i loosened the radius arm nuts, was adjusting the camber and noticed the plate that the camber adjustment bracket bolts through has pulled up.
even with full +ve camber i only get this much clearance
do you think i have a right to complain to huddersfield spares aboutthe beam axle?
has anyone else had this problem?
cheers
#55 Jackman
Jackman
  • 4,053 posts
Posted 07 March 2009 - 11:53 AM
Id get onto huddersfield spares about the beam axle, thats bad. Id say its close on dangerous it bending and you havent driven it.
Are you running spacered rear drums?
#56 evil ewok
evil ewok
  • 354 posts
Posted 07 March 2009 - 04:45 PM
writing them an email now and going to send them pics, having to restrain myself from being abusive though lol
yeah running mini sport super fins which have a built in 1" spacer
#57 Jackman
Jackman
  • 4,053 posts
Posted 07 March 2009 - 05:22 PM
Silly question (never seen or used coilovers) do you have the coilovers on the right side?
From this picture it looks like if you swap sides it will move the coils further away from the wheels and towards the body?
*Note*
This could be utter twoddle and no use :)
#58 evil ewok
evil ewok
  • 354 posts
Posted 07 March 2009 - 06:15 PM
*Note*
as far as i know i dont think they have a specific side. the top pin is offset to move the top further away from the body work to allow the coil to fir as they have a larger diameter than a standard style shock. but now you've said that i'm going to check tomorrow when im down there lol
#59 Jackman
Jackman
  • 4,053 posts
Posted 08 March 2009 - 09:35 PM
Did you find out anything about this?
#60 evil ewok
evil ewok
  • 354 posts
Posted 08 March 2009 - 11:44 PM
hada quick look but teh only offset piece i could see was the top pin, which can be turned whilst on the shock so can be used on either side. didnt spend to long looking as went offroading with my mate in his land rover with no roof.. then it started to rain and hail, so we carried on driving lol
8 user(s) are reading this topic
    Bing (6)
