Project 'lesbian Rose'
#31
Posted 02 February 2009 - 10:36 PM
i got a soft spot for these
http://www.minispare...mp;prod_id=1999
rob
#32
Posted 03 February 2009 - 07:57 PM
ooh yes very tasty, £420 a set tho, bit steep!
rob
the supertrax will be a maybe later on when i have more money, for now the butch one shall stay rollingon her pimp steelies lol need to get them powdercoated with the final body colour choice pinstripped in the dish, but first the car needs building.
i quite like those deep dish superlights, not overly keen on the gold though, but thats just personal taste
#33
Posted 03 February 2009 - 08:04 PM
hmmmmmm may end up going second hand rims yet so who knows.
rob
#34
Posted 03 February 2009 - 08:24 PM
what pressure fuel pump do i need for the k series? i have a turbo one sitting in the garage but was wondering if i could return that as it cost about £100 and use a facet, then could put the money towards a fuel tank
#35
Posted 03 February 2009 - 10:14 PM
tried to drop the rear subby today to fit the rear beam axle but 5 of bolts have seized
tried using wd40 but with no luck so i've borroweda 24v impact gun from my brother and will give that a go tomorrow.
facet pump ftw!
oh and try getting torch on bolts.
rob
#36
Posted 10 February 2009 - 06:37 PM
still haven't managed to get the subby off, a couple of the heads snapped of the studs and a few just rounded off so will drill/grind the head off tehn use a stud extractor. raqdius arms are off though so will begin to recondition those ready to go onto the beam axle.
ordering a bare subby from allspeed engineering which should save me some hassle of trying to build one, now to sort out thh wiring loom and source someone to make the custom driveshafts
#37
Posted 11 February 2009 - 06:16 PM
http://www2.obp.uk.n...91288e618185bed
from what i've read the k series means i will have to change my brake master cylinder and remove the servo, so was wondering if one of these would be useful? plus i think they look awesome lol
#38
Posted 15 February 2009 - 07:29 PM
what should i do? is there anyway of just grinding off and welding new nuts on to the inside of the heelboard to replace them, or do i need to replace part of the panel?
help! need to fit the beam axle to get the shell rolling again.
#39
Posted 20 February 2009 - 11:49 PM
stripped down and painted the radius arms, fitted new spindles, bleed nipples, thrust washers and rubbers.
still need to fit new shoes, superfins and braided lines
the rear seatbelt mounting points have been boxed in as they sit under the new flat boot floor
the rear subby front mounting points were a bit rusty so have been replaced along with part of the boxed area inside
looks like i need to re-tap one of the captive nuts as the thread was damaged during fitment.
the fuel filler cap has been filled in
i have skimmed it with filler to build up the shape but forgot to get more photos
some of the bulkead holes and the inner wing heater ducting intake hole have also been patched, the boot floor has now been seem underneath on the overlap and all of the interior sound proofing has been removed...but forgot to take pics of it all
Edited by evil ewok, 20 February 2009 - 11:49 PM.
#40
Posted 22 February 2009 - 08:59 PM
was hoping to bolt on the beam axle and suspensions so i could get the shell on all for wheels again today, but its been held up by 1 nut. the thread on tone of the subby mountcaptive nuts got abit damaged when the mount repair panel was being fitted
waiting on my allspeed front subby so i can start orting out mounting of the engine, and working out what needs moving/modifying.
been thinking about paint schemes for the project but cant make a decision. ideas so far are:
1) kawasaki green with blue arches (similar to the blue of cobra seats)
2) ford signal yellow (or another bright yellow)
3) bright orange and blue arches
4) original rose colour schem
or my brothers suggestion..
5) black with rose pink roof and arches, with rose decal in pink and 'lesbian' above it in scroll writing, like and evil rose lol
what do you think?
(could this be moved to the rover engine conversion section please)
Edited by evil ewok, 22 February 2009 - 09:22 PM.
#41
Posted 22 February 2009 - 09:07 PM
hows the k series side of things coming along?
and all of those paint scemes woud look good but most have been done already.
i think you should go for something different - maybe black with the green arches and roof?
be bold!
rob
#42
Posted 22 February 2009 - 09:20 PM
looking good mate, realy cooking now!
be bold!
rob
still finding rust with each cut lol. quite drawn towards black with a outrageously bright highlighting colour on arches and roof. does black show up the imperfections more? thats my biggest worry with painting lol could always just laquer it as it is, show off all the layers of paint and filler
as for the k series side of things, can't do too much until get the frame and start mounting it. on the search for engineering companies to make the driveshafts, and started sorting out the mini and engine loom the other day to try and start splicing them together.
started mounting the digidash into the zcars dash yesterday, just need to work out if im using original switches or going for something different?
hows your clubby coming along? i should hopefully be starting to build a 998 for my clubby soon so may have a 1275 being freed up if your still after one at the time.
#43
Posted 22 February 2009 - 09:26 PM
black is a bit of a *woman of ill repute* for showing imperfections up mate! you could go matt black tho! lol
as for just lacquering it well aparently the rat looks in at the moment lol.
rob
#44
Posted 24 February 2009 - 07:27 PM
"Morning Luke
I see from your e-mail, you have at last succumbed to the dark side – Welcome
Anyway, back to the shafts for your X-wing, as long as the pressure angles on the splines are either 37½ and 45 degrees, we are able to assist..."
what are the pressure angles and how do i find out what they are? unless anybody already knows the answer?
i have bothe the mini and k series drive shafts in the garage
cheers for the help
#45
Posted 02 March 2009 - 11:10 PM
i'll let the pics do the talking...
the back sits quite low now with the coilies on their lowest setting, the tyres rub on the arch lip lol
