Project 'lesbian Rose'
347 replies to this topic
#331 evil ewok
evil ewok
  • 354 posts
  • Local Club: A's of Herts
Posted 14 May 2015 - 09:23 PM
Not much has happened lately as work has been rather busy now race season is underway.
With a bit of trimming the rad fits under the front end
although it is a rather tight fit!
got a few more hoses sorted and started to re-position the oil cooler from down below for it's own protection
Think I'm going to move it to the other side in front of the water pump though so I have an empty space if I decide to use an air scoop/ram air setup later on
Started fitting the mini spares adjustable camber/toe brackets
going to need a slight adjustment though....
Cut out the gear linkage housing mount from inside as having some threaded bosses welded on to the housing and so changing the mount. Also chopped of the subframe brace bar bulkhead mounts as moving them further out for more clearance for water pump etc.
On a different note started to strip a few bits off of the clubman as hoping to start work on restoring it at the end of the month and decided to poke it a bit with a screwdriver. I wish I hadn't.
What started out as a single hole in the sill became this....
Also, probably a stupid question, but did mk3 shells have the hole in the tunnel for magic wand gearshift or could this be a left over mk2 shell that was used?
found this plated magic wand hole under the carpets
#332 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 25 August 2015 - 08:39 PM
Any updates on this? I love the Miglia style!
Did you sell the K-series subby?
Edited by Will16, 25 August 2015 - 08:39 PM.
#333 evil ewok
evil ewok
  • 354 posts
Posted 25 August 2015 - 09:51 PM
Yeah I sold the k subby a while ago now mate.
I've done a few bits to it but problem is when you spend all week working on classic race cars, the last thing you really want to do is work on your own haha
I'll have a look through pics on my phone and try to get something together on what I've done/bought for it recently
#334 evil ewok
evil ewok
  • 354 posts
Posted 27 August 2015 - 12:04 AM
Right, just a quick update as i'm half asleep already...
Bits bought that I can remember:
Penske dampers.
just a little shorter than the gaz
TRS tow straps
Schroth profi II 6 harness for me
Bought the tow straps and harness through work so i could use their discount haha. Considering a Race Technology Dash 2 but not 100% at the moment
http://www.demon-twe...-road-dashboard
Jobs done:
Bought some shiney an fittings from Torques and hose to re make the oil lines, also moved the oil cooler to the other side of the engine
fitted the penske dampers
need to make a small adjustment to the subby towers for clearance...
rear suspension no longer falls out!
before
after
made some rad mounts which still need trimming
made some new subby brace bars bulkhead mounts. welds weren't too bad seeing as i havent used the welder in a while
also started re doing the gear stick housing mounts as they've been changed but have no pics of that
going to order brake line bits soon through work but can't decide which colour to go for ....any opinions?
#335 coopdog
coopdog
  • 4,506 posts
Posted 27 August 2015 - 08:19 AM
Go for pink
#336 evil ewok
evil ewok
  • 354 posts
Posted 27 August 2015 - 08:32 AM
I have been thinking pink but wasn't sure if it would be too much with the pink roof,arches and grille
#337 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 27 August 2015 - 10:00 AM
If you've already got some in silver - continue with silver.
If you're starting your lines again from scratch - I'd go with pink.
What size are the oil hoses from Torques - AN8?
Cheers,
Ian
#338 evil ewok
evil ewok
  • 354 posts
Posted 27 August 2015 - 12:56 PM
I've got braided silver lines connected to the callipers and drums at the minute but will probably replace them.
Looks like pink it is then....
Yes An8 mate.
#339 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 27 August 2015 - 01:21 PM
Wow just had a good read of this build over my lunch some serious work has gone in to this build its mental, so glad your back on the a-series idea though a-series all the way for me, like the little nods your doing to the original Mini Rose. Watching this one cant wait to see it done it looks like it will a be a right weapon....
#340 evil ewok
evil ewok
  • 354 posts
Posted 29 August 2015 - 06:46 PM
Cheers, it's nice to know people appreciate the work.
Had a little go at it again today
finished making the oil cooler mounts on the brace bar
also finished off the gear stick housing mount
as you can see had to fill a couple of blow through holes where i hit thin metal
#341 Chris1992
Chris1992
  • 2,022 posts
Posted 11 April 2016 - 12:31 AM
any updates on this?
#342 evil ewok
evil ewok
  • 354 posts
Posted 26 June 2016 - 04:26 PM
Not much has really happened I'm afraid. Bought a few bits but not really worked on the car. After a week of working on other peoples cars at work I never feel like going to the garage unfortunately.
Bought myself a birthday present back in December
Mini Spares 7.5"  alloy 4 pots, spacer kit, vented discs and new drive flanges. They still sit in the box waiting for the spacers to be fitted to the calipers....
A couple of months ago I bought a Race Technologies Dash 2
That also sits in its box in my bedroom..... Need to talk to my friend nicely about making a carbon dash binnacle for it
Halfords had a sale on the other month, I also had my trade card plus a discount voucher so had a little spending spree and bought a new tool box plus some new tools, hammers and torque wrenches
Haven't really used any of the tools since.....
I originally had some 1.5:1 roller rockers on the head for this build but I found out I'd have to reduce valve spring poundage or risk damage. So the 1.5s were moved on to the mk3 cooper s head for the clubman
and I purchased some MED 1.3:1 roller rockers
plus some one piece CNC'd push rods to go with them
Also purchased a Facet red top fuel pump with -6 fittings
Need to have a sort through the garage and get rid of parts no longer required, like the +90mm fg front from the engine conversion stage still lurking in the back taking up valuable space
Edited by evil ewok, 26 June 2016 - 04:33 PM.
#343 evil ewok
evil ewok
  • 354 posts
Posted 13 August 2016 - 07:21 PM
Spending most of my money lately buying parts to start the Clubman rebuild but I did manage to get a freebie from work to fit my fat arse in to easier....
Came from a customers race car and it's FIA approval date expired in December. Can no longer be used to race so talked the boss in to letting me make use of it  :D
#344 patto
patto
  • 199 posts
Posted 19 January 2017 - 05:40 PM
Hi nice project and I like the use of pink.
I’d strongly advise not using the vx220 seat with harnesses I have a vx220 myself and it has been discussed at length on the various forums. The problem is the sloped shape of the shoulder pads causing the harnesses to slip apart, some people have put harness cut outs in them but there’s also a lot of debate around if the seats would cope with the loading caused on them by the harnessed in a crash.
You have negated the main problem with them though with the 6 point harnesses that is you can submarine out from under them due to the low down seating position in a vx220. There was quite a nasty crash on the vx forum some time ago where one was T-boned by a seat Leon and had the whole front end ripped off and the driver submarined out from his harness and was thrown from the car, as you can see in the photo the drivers harness (left hand drive car) is still fastened.
Anyway I’ve been waffling a bit but my point is these seats aren’t designed for harnesses, yours may be alright with 6 point harnesses but it’s probably not worth the risk. I’d just use a small bucket seat that’s designed for harnesses.
I don’t mean to be all preachy I just wanted to make sure you have the necessary information, the rest of the work is great and I’ve enjoyed reading through your build thread.
#345 evil ewok
evil ewok
  • 354 posts
Posted 20 January 2017 - 04:56 PM
Thanks for the info, but no need to worry as I don't plan to use this seat anymore. Just been putting all funds in to the other car project so haven't got round to buying another seat. Main problem is I'm rather limited for space so would have to be something like a kit car seat, a kirkey or a Tillett. Would love a Tillett but I doubt funds would allow it! (and all of the ones in the race cars a work are still in date :'( )
Haven't really touched this lately as been focused on other things will hopefully get back on it soon and give an update
