Project 'lesbian Rose'
#16
Posted 24 January 2009 - 03:24 PM
ive only seen a couple done. prob why people tend to go for the vauxhall or honda engine.
#17
Posted 25 January 2009 - 09:15 PM
i looked at the k-series when i first got into minis, the subframe is quite abit wider and you need to be very competant at your welding and engineering abilities.
it will be my mate doing the welding, and he gets a lot of practice fixing all the holes and rust on my mini,his triumphs and xr2i lol both him and my brother done mechanics so will get a lot of help. i've found a few designs on the forum of frames for the engine that are roughly the same size as a standard one so will most likely try to create something similar
only thing is where would i get the custom drive shafts from? or is it possible to make them myself?
#18
Posted 29 January 2009 - 07:33 PM
also bought a digi dash pod
http://www.digitalsp....co.uk/rx2n.htm
comes with sensors for oil, speed etc which is useful, now just to try and work out the wiring
also bought a spare steering column, cowling (with sidwards facing barrel), barrel and stalk for the clubby, only £20 which i didn't think was too bad
#19
Posted 29 January 2009 - 08:09 PM
damn, i wanted that!!! £25 for it!!?
liking the project ideas! i was thinking of getting a rear beam...
#20
Posted 29 January 2009 - 09:09 PM
damn, i wanted that!!! £25 for it!!?![]()
sorry mate, need the ignition barrel as long as its ok as mines worn and can remove the key with teh engine running
cheers for the encouraging comment, everytime i look at it i realise how much more work is left to do lol went to remove the old rear subby earlier and 2 bolts are seized
#21
Posted 29 January 2009 - 11:23 PM
#22
Posted 30 January 2009 - 08:40 PM
need the actual column... my splines have worn on the bottom of mine... ive tightened the pinch bold as much as i can....
if i take the cowling , ignotion and stalk off you can have the steering column
#23
Posted 01 February 2009 - 09:48 PM
rob
#24
Posted 01 February 2009 - 10:02 PM
its only a 1.4 but should give a bit more power than the old 998 that kwik *melon* killed
this is the only pic that came out properly so will get some more of the engine and other parts tomorrow. now just need to get off my rectum and start sorting out parts for fitting it, but first need to finish off sorting out the rust lol
(could this be moved to the engine subforum please)
#25
Posted 02 February 2009 - 09:48 PM
this is the half done modified subframe that came with the engine, not sure if i will use it yet.
all the other bits that came with teh engine (loom, driveshafts,alternator, part of manifold, ecu etc)
garage needs bit of a tidy so i can actually get in lol
been a bit cold to do anything today
#26
Posted 02 February 2009 - 10:06 PM
i dont supose there a nice 1275 hiding under all that lot that you want to sell me?
rob.
PS- Fire up the mig and get the k lump in!!!!!!!!!
#28
Posted 02 February 2009 - 10:14 PM
Luke, if you ever have a party in your garage - i want to be invited! sooooo many parts / bits to play with!
rob.
PS- Fire up the mig and get the k lump in!!!!!!!!!![]()
dont have a spare one yet, will do in the future when i build a road/race n/a 998 for the clubby
i probably have half a car in spare parts sitting in the garage lol (engine, body and interior)
i cant weld
#29
Posted 02 February 2009 - 10:18 PM
the 1.4 k series puts out 105 bhp so should be plentyful fun ness!
keep us posted on your plans, when u think you will be shifting the 1275? may time?????
also i think you should donate your wellers to project barry!
rob
#30
Posted 02 February 2009 - 10:24 PM
that subby maybe good for mock up build / test fit
rob
engine depends on money and how fast 'lesbian rose' moves along, takes abit longer doing everything yourself (except welding) when you dont have much of idea of what to do lol
if donate the whels what am i going to roll on? brake discs dont have much of a rolling diameter lol although if i could afford it them i rally want a set of satin black 7x13" supertrax wheels
http://www.minispare...mp;prod_id=2193
