well it's been a while but i've been plodding along with this as and when i can whilst back from uni. had to fix the french tractor run around before i could crack on again with the mini.
anyways i decided to cut out the old turbo box which had been hacked about and extended for gear linkage as it looked rubbish.
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG068.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG070.jpg)
after seeing what was behind some of the patches i had done for me before i decided to cut off his patches behind the front suspension top mounts...
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG099.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG100.jpg)
decided as i had to remove a fair bit of the inner wing to de rust i may as well remove the un-needed holes and do some thing elsei wanted to do...
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG106.jpg)
going to be reshaping the inner wing, like endaf owens does on his miglias, and use 3mm to shape and also create a new gusset to the crossmember and plate for bonnet pin and an extra fg front mount on top
made up a new, smaller box for the gear linkage
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG112.jpg)
some more of the large hole filled. none of it is welded in, just making plates and waiting for some decent weather and my intergrips to arrive
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG121.jpg)
can sort of see my plan here. rebuilding the crossmember without the original clearance dip for the carb. still need final bend doing on the bottom to make the lip so sticks to far currently.
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG123.jpg)
then made a few small changes to the inner wing lip piece to include a gusset to the crossmember and a plate for the bonnet pin. cut and form both sides
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG131.jpg)
the bulkhead side mounts up to the bonnet pin plate/gusset
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG130.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG129.jpg)
just a random pic of the back end
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG043.jpg)
decided to try an exhaust out if i were to use original mountings
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG089.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG093.jpg)
a bit tight haha i'm hoping to get some miglia backboxes turned on their side and sitting up high
also happy i raised the engine up in the frame when i built new engine mounts as i now have enough clearance to fit a manifold underneath even at its lowest height (sitting on bumpstops)
![:D](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/grin.gif)
got an issue with not being able to fit the inner bush in on the rear subframe mounts
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/100_1421.jpg)
decided i'm going to solid mount it solve this but unsure whether to use 3mm or 5mm to make the mounts? they will just be folded plate with 1 or 2 gussets
here are just a few random pics that have been taken over the last couple of months
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG046.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG045.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMG044.jpg)
the more i look at this pic the less i like the extended front
![:(](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sad.png)
