had to shorten the turbo box, remove the bulkhead box and remove the dash rail to get the pedal box to fit in place.
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMAG0180.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMAG0184.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMAG0185.jpg)
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMAG0186.jpg)
pedal box rear mount done
![Posted Image](http://i43.photobucket.com/albums/e351/evil_ewok666/mini%20project%20lesbian/IMAG0189.jpg)
Posted 02 January 2011 - 05:38 PM
Posted 02 January 2011 - 05:39 PM
Posted 02 January 2011 - 05:40 PM
Posted 02 January 2011 - 05:41 PM
Posted 02 January 2011 - 05:43 PM
Posted 02 January 2011 - 05:44 PM
Posted 03 January 2011 - 10:19 PM
Posted 03 January 2011 - 10:50 PM
oh ok... its just i had the same problem spent a week trying to get the bugger off turned it round a inch and the f**ker popped straight off hahathe clutch is off the engine!!!! finally managed to get it off, after a few hours of attacking it with an angle grinder. had to almost chop it in half to get it to release from the crank!
its a good job i'm replacing the crank as it got a little damaged lol
the u washer thingy was still in position even though i'd had to turn the crank whilst the flywheel bolt was out.
the clutch housing has been damaged even more so will def.. be needing to replace that too
just a question... did you try turning the flywheel till the closest piston was at its highest point then try to lever it off???... i thought mine was stuck till i found that out as haynes doesnt actually tell you that???
started off with the piston at TDC but when it wouldn't come off started to turn it so i could hit it evenly around the flywheel to try and release it, but had no luck either way
Posted 30 January 2011 - 04:10 PM
Posted 21 February 2011 - 09:18 PM
Posted 01 March 2011 - 06:08 PM
Posted 15 March 2011 - 12:04 AM
Posted 15 March 2011 - 10:21 PM
Posted 16 March 2011 - 12:47 AM
