Mg Metro ( Super Charged )
#16
Posted 08 January 2009 - 11:43 PM
#17
Posted 09 January 2009 - 12:12 AM
With it mounted like that you could use an intercooler as well couldnt you?
Yep
This set-up should give better results than the charger kits that are avalable on the market.
#18
Posted 09 January 2009 - 09:13 AM
also, is that the only mpi manifold you have?
#19
Posted 09 January 2009 - 03:48 PM
hi stig , what injection ecu will you run?
not got to that bit yet , will proberly be megasquirt vems etc
have another manilfold but not got all the sensors etc
dids see one complete on ebay the other day though after searched under mpi
#20
Posted 09 January 2009 - 05:08 PM
#21
Posted 10 January 2009 - 09:19 AM
i have a MS unit going spare. don't think i'll be using it. if your interested. has loom too. was pro built and tested. used it on the redtop originally
#22
Posted 28 January 2009 - 06:28 PM
Have you thought about a fifth (or, third in this case I guess) injector for full throttle?
yes
bought theses bike throttle bodies with injectors came of a speed triple so will just remove one of them
which i will mount to the supercherger giving me 4 injectors in total
not sure yet if will use the butterflys and have it as suck though or remove the butterflys and use my 55mm throttle bodie on the manfiold and have it blow through
also have a inter cooler from a saab
Edited by THE STIG, 28 January 2009 - 06:29 PM.
#23
Posted 01 February 2009 - 02:15 PM
use the same type of injectors found on minis/rovers so can have 4 injectors all running the same wiring etc
Edited by THE STIG, 01 February 2009 - 02:18 PM.
#24
Posted 01 February 2009 - 02:18 PM
How much did that cost? How well will you be able to fit it?
#25
Posted 01 February 2009 - 02:20 PM
nothing and by plumbing it between supercharger and manifold (if i use it )
#26
Posted 01 February 2009 - 02:49 PM
Will it need much modifing?
#27
Posted 02 February 2009 - 08:53 AM
will what need much modifing ????????
#28
Posted 02 February 2009 - 01:11 PM
The Saab intercooler, or is it small enough, etc?
#29
Posted 30 September 2009 - 08:43 AM
#30
Posted 08 April 2010 - 09:48 PM
