Water pump gasket?
Telejmp
, Mar 06 2004 02:00 PM
26 replies to this topic
Posted 06 March 2004 - 02:00 PM
I have a fast water leak from my mini, Ive took the alternator and everything off, and it looks to be coming from the back of the water pump.
Is there a gasket behind the pump when you take it off? If so where can I buy one, Ive looked on the net and cant find any.
pEaCE
Dom
pEaCE
Dom
Posted 06 March 2004 - 05:07 PM
might aswell buy a new pump only about 10 quid and then u get the right gasket
Posted 06 March 2004 - 07:09 PM
Make sure u get the right sort tho, the older sort have a byepass hose goin to the head, this is a *Female doggy*!! They leak all the time!
Posted 06 March 2004 - 11:23 PM
working on bluemini(red)'s line have you checked the hose a loose clip could be you problem!!
they are a pain to renew :grin: but worth it :wales:
Posted 07 March 2004 - 12:05 PM
Hey,
Ill pick up a new water pump sometime this week then.
Cowboy, I checked all the hoses I could see, it looks to be coming from the back of the water pump. Ill have another check though before I go buying a new pump,
Thanks everyone,
pEaCE
Dom
Thanks everyone,
pEaCE
Dom
Posted 07 March 2004 - 04:40 PM
The byepass hose is about 5cm long and is tucked rite up under the head so you may not see it without taking your rad off... They are a b****rd to do too. Easyest way is to take the pump off...
Posted 07 March 2004 - 10:56 PM
don't go wasting your money by buying a new water pump when all you need is a gasket, if need be they can be made..all you need is some good card, and some instant gasket, it does the job well, alternativlly if you don't have instant gasket use hylamar. works wonders.. :wales:
Posted 10 March 2004 - 02:03 PM
How long would you think that instant gasket would last?. At the moment I dont have much money and I like the sound of making my own gasket, hehe.
When I get some money coming in, I need to replace the front subframe, I can always go around and fix everything ive bodged when the engine is out, and replace the parts properly, hehe.
pEaCE
DOm
pEaCE
DOm
Posted 10 March 2004 - 08:00 PM
if you make the gasket yourself and use the right instant gasket to go with it, it will last as long as a new gasket would, if you were to buy one..
the best one i use is a loctite instant gasket 574.. its orange and should be able to pick up art most good suppliers......
:wales:
:wales:
Posted 10 March 2004 - 10:41 PM
gasket will cost you sod all, do the job properly to start with mate.
Posted 11 March 2004 - 08:36 PM
What should I use to make the gasket with, Just any thinish card?
I would buy one if I could find one, but I cant,
thanks,
pEaCE
Dom
thanks,
pEaCE
Dom
Posted 11 March 2004 - 09:00 PM
Do as Mini7 says and do it rite the first time, its not worth the hassle of all the muckin about tryin to budge it, when you can get a new gasket for bout 50 pence...
Posted 11 March 2004 - 09:02 PM
*cough* :tongue:
Posted 12 March 2004 - 04:21 PM
Oh thanks guys,
I diddnt know you could buy replacement ones for the waterpump, Ill try and get one sorted,
pEaCE
Dom
pEaCE
Dom
