Will These Drive Shafts Fit?
Posted 03 January 2009 - 08:22 AM
linky to drive shafts
Posted 03 January 2009 - 09:13 AM
The mah have disk cv's on the end but they don't look thick enough to be cooper S shafts.... and having crucifix joints on the other end suggests they are also non cooper S ( as they would have hardy spicers )
I assume you have crucifix joints on your gearbox and is the reason why you are looking at these..
Posted 03 January 2009 - 07:50 PM
Posted 03 January 2009 - 07:53 PM
Posted 03 January 2009 - 08:12 PM
Posted 03 January 2009 - 09:27 PM
They will fit either disc or drum brake CV joints.
The Cooper S shafts are noticeble by a wide ridge half way or so down the shaft as can be seen in the picture attached
Posted 04 January 2009 - 08:33 AM
If you have either the Hardy Spicer or the rubber coupling inner joints, these shafts will fit. They will not fit Inner Pot type joints.
ok thanks so are you saying the ones in the link i attached will fit? thanks shane
Posted 04 January 2009 - 08:37 AM
Posted 04 January 2009 - 03:21 PM
As for these fitting where Hardy-Spicers are installed, No, I don't think so. The differential outputs are different on Hardy-Spicer cars. The shafts in the auction would be suitable for someone with an early -S like mine, or someone whose gearbox has the yoke outputs and wants to upgrade to 7.5" disks.
Posted 04 January 2009 - 03:47 PM
Posted 04 January 2009 - 05:03 PM
thanks shane
Posted 04 January 2009 - 05:47 PM
John, EARLY Cooper-S cars (like mine) do indeed have this style driveshaft. My car is a 1964, Hardy-Spicers came later.
There are only two 'styles' of 'driveshaft'
That is early rubber coupling/ hardy spicer (without distinguishing between Cooper S, for arguments sake) and Late Pot joint.
Have a search around
If you were talking about the inner coupling joints, then the ones in the auction attatched to the shafts are the early rubber coupling and yes they will not fit on a gearbox with hardy spicer couplings. But if its only the driveshafts you are after, it wont matter what coupling you have as long as its either rubber coupling or hardy spicer. Those couplings both have the same splines.
Also it doesnt matter what CV joint you use, Disc or Drum, both cv joints use the same splines.
Which leads to the question, what is the real reason for purchasing said shafts? Disc conversion? you only need to change the outer CV for the correct one. Inner coupling? is the rubber coupling the one you need or is it hardy spicer? or, are you just after the shafts to replace the ones you have? in which case as long as you have either rubber coupling or hardy spicer inner joints, they will fit, as said before.
Remember there are only two styles of drive shaft, distiguishable by the inner joint type. Pot joint or Hardy Spicer/ rubber coupling.
Posted 04 January 2009 - 06:05 PM
thanks shane
Posted 04 January 2009 - 09:34 PM
That is early rubber coupling/ hardy spicer (without distinguishing between Cooper S, for arguments sake) and Late Pot joint. Have a search around
Sorry if my post was unclear. I was referring to the driveshafts as a whole including the inboard drive "method". What I was trying to convey is that the yoke-type driveshafts were used on early Cooper-S. I was also trying to say that the output gears on the differential were different between yoke-type and Hardy-Spicer. That is to say, IF you wanted to convert a gearbox from yoke-type to Hardy-Spicer, it's not as simple as getting the Hardy-Spicer output flanges and putting them on the gearbox, it's my understanding that the differential output gears/shafts have to change. Please feel free to correct me if I'm wrong.
See the exploded parts diagram at this site:
http://www.heritageg.../gearbox/19.htm
and look at item 12 both in the picture and the numerical list.
Regardless, the auction has closed.
Posted 04 January 2009 - 10:38 PM
