What Oil To Use In Dash Pot On Carb
14 replies to this topic
#1 ace
ace
  • 140 posts
  • Local Club: Posh Mini Owners Club
Posted 30 December 2008 - 10:40 AM
Hi
what type of oil do I use in the dash pot on the carb - also how much is there an indicator on the dash pot lid and how full do people have it??
thanks
#2 Asphalt
Asphalt
  • 2,173 posts
Posted 30 December 2008 - 01:16 PM
I prefer to use automatic transmission oil.
Other swear of 15w40, others say 15w40 is the real thing, some tell you it only works with 20w50 and get blamed fo giving incorrect advice by the ones propagating 10w40.
Oh - and your local SU parts supplier of course tells you only original SU dashpot oil is the true thing...
Now awnser it to yourself :wub:
Opinios are wide spread.
Fill it up 'till the inner tube (were the damper goes in) is full.
It will level itself out then.
Regards,
Jan
#3 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 30 December 2008 - 01:56 PM
You'll be fine with any of the following...
20w50, 10w40, 15w40, Air tool oil, anything of that sort of consistency.. some people say that 20w50 can give better preformance however when it gets warm it changes consistencey..
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 December 2008 - 04:44 PM
Anything of which of those four different viscosities in particular then? :wub:
If you want the carb to perform to OE spec then put SU damper oil in it. If you are trying to tune it to respond differently then you'll have to keep using different oils until you find one that you like. The viscosity of the oil and strength of the damper spring working together determines how fast the carb reacts to throttle changes. 3 in 1 is pretty similar to SU damper oil. The oil isn't going to get very warm in the dashpot, the carb is essentially refrigerated.
As for oil level, it should be 1/2" below the top of the damper tube. That's the inner tube that you can see inside the dashpot. If you over fill it don't worry, it will level out as the engine will slowly draw some off and burn it.
#5 liirge
liirge
  • 4,097 posts
Posted 30 December 2008 - 04:47 PM
Ha!! you know what i meant,
#6 blue redtop
blue redtop
  • 1,605 posts
Posted 30 December 2008 - 05:12 PM
3 in 1 oil works great for me.
#7 blacktulip
blacktulip
  • 6,224 posts
Posted 30 December 2008 - 06:01 PM
i have used 3in1 for 8 years now on 5 minis of different tunes.
#8 robtheplod
robtheplod
  • 960 posts
Posted 30 December 2008 - 08:20 PM
sorry, still learning here - what is a dash pot??
Edited by robtheplod, 30 December 2008 - 08:20 PM.
#9 Pauly
Pauly
  • 4,213 posts
Posted 30 December 2008 - 08:24 PM
Its the sort of big cap which the black cap ontop of the carb screws into, it houses the damper and piston/needle.
Paul.
#10 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 30 December 2008 - 08:25 PM
The screw bit on top of the carb.
#11 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 30 December 2008 - 08:32 PM
I also use 3 in 1 now, works perfectly.
#12 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 30 December 2008 - 11:34 PM
I've used 3 in 1 since day one, my mate laughed in disbelief but that's why my car has been on the road for 19 years, 2 of which I've had it, and his has been off the road for 3 years. Hah.
#13 tnewson
tnewson
  • 78 posts
Posted 01 January 2009 - 04:46 PM
My haynes manual says that 10W 40 is the oil to use.
#14 carthy79
carthy79
  • 45 posts
Posted 01 January 2009 - 05:29 PM
I was once recommended to use Extra Virgin Olive Oil - ideal viscosity for SU carbs. haha :thumbsup:
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 January 2009 - 05:38 PM
It will rot.
