1989 Austin Rover Retro Mayfair
#151
Posted 14 June 2010 - 10:24 PM
#152
Posted 16 June 2010 - 09:06 PM
#153
Posted 17 June 2010 - 09:46 PM
And now I’ve been playing around with the door, it appears the rear edge of the a panel isn’t inline, but nothing the old G-clamp and metal pole shouldn’t be able to sort.
Some of the front in it's first proper coat of green (yes i know the front is a little high lol)
And before I go welding on number plate brackets I need to decide what type of plate I want to run ???
And i'm also now tempted to two tone it, with the roof and bonnet in a slighty darker green than the rest ???
#154
Posted 20 June 2010 - 09:28 AM
#155
Posted 20 June 2010 - 09:15 PM
But as my fixing pates on the a panels have pulled the back of the wings out, I have now been left with quite a bit of a gap down each side of the bonnet.
Edited by 1984mini25, 20 June 2010 - 09:16 PM.
#156
Posted 20 June 2010 - 10:27 PM
#157
Posted 21 June 2010 - 09:20 PM
#158
Posted 21 June 2010 - 09:41 PM
mrm
#159
Posted 21 June 2010 - 11:46 PM
But…
Hear goes…
I’m painting via a roller and dulx gloss.
I’m still not saying what shade of green though, I did also try spraying it, but the white sprit did funny things to it, so I decided against that option.
Once I have it all in one colour and finally happy with how straight it looks, I’ll rub it down so it’s nice and smooth and give the whole car a few coats in one go to get the colour nice and even and then lacquer it as well.
As the first coat or two tends to be a bit thick to get the coverage, but after that it can be rolled on a lot thinner to build up the colour and finish.
Although if you look back a page or two you’ll see the finish I’m getting with minimal prep, been using these grey foam sanding blocks used wet, straight from the tin and just rolled on with no sanding or polishing after.
#160
Posted 21 June 2010 - 11:52 PM
#161
Posted 24 June 2010 - 09:46 PM
I'd love to get the rest of the engine together, onto the gearbox and in the front frame. But the one item thats been stopping me has been out of stock via minispares for the past 6 or so weeks.
#162
Posted 25 June 2010 - 09:27 PM
Mesh fiberglassed to back of bonnet, I’m hoping on making it look a bit neater, as it was rather messy.
Bonnet vents with mesh, yes I know that’s a lot of filler, I haven’t sanded it yet and with the weather being so warm I was more worried about getting it on the car before it set Lol.
I’ve also been working on a filler panel to close the wing to scuttle gap buy using an old seam trim. As when I put the extra trims on the wings it pushed the hole front end forwards, increasing the gaps, so hopefully once fully welded in and ground flush it should close it back up again.
And as I had some spare mesh left over, I’d though I’d see what it would look like with some behind the mk1 grill.
#163
Posted 28 June 2010 - 09:49 PM
#164
Posted 29 June 2010 - 01:23 PM
#165
Posted 08 July 2010 - 10:10 PM
So door gap all fixed and welded up, bar a bit of grinding if i'm being picky.
Also made a start on the inner hinge/ a panel blanking cover, same as what I’ve done on the drives side. But only got as far as taking it in place, so have yet to fully weld it
