4x4 ! Discovery Scrapped And Discovery Saved !
#16
Posted 26 December 2008 - 03:14 PM
no minis i have wrecked have been good and neither have any ladrovers including that 1 !
it had rust all down the inner wings and i had also bent all the body after jumping it
well bad guess aswell because anyone who knows what thier talking about would know instinctively that tha hole is for a snorkle ( now removed ) DUH !
also onlymelloyed thanks for that info iv checked the 110 and cant really see anything that relates to it bein an ex-armylandrover and iv also discoverd 2 places where the paint has come off and the bonnet was red and the body blue and inside was green......
also some pics of them are comming up.....
THE 110
THE 90
THE 300TDI
thir the pics i can find atm i cant find anyof the series 2 yet so ill just keep checking as takes me ages to take sum and put them on ere
might find it interesting that the 90 had a 200tdi discovery engine in it aswell
needs to get a few bits sorted but its in and rus and drives really well !quite quick aswell consiering all the less weight u have !
#17
Posted 26 December 2008 - 05:35 PM
military doors with sliding windows
also the rear cross member should look like this:
as far as breaking mini's or land rovers at the end of the day its up to you what you do with your own cars so don't let people get to you and good luck with your defender project
#18
Posted 26 December 2008 - 05:39 PM
#19
#20
Posted 26 December 2008 - 05:47 PM
#21
Posted 26 December 2008 - 06:02 PM
the doors do look the same as yours and on the inside they have black solid door cards? dont know if this is army or original?
the rear crossmember looks standard and the chassis is mint and not welded and the whole landrover is original to how it was made
the engine is the old 2.5? not sure if its turbo or not but i dont think so
the blue discovery is having its engine and box ripped out and the 2.5 turbo is going into the 110
not sure what were going to do with the rest yet but as its taxd and MOT'D i might just chuck the V8 in but leave the rest as it is
dont suppose u know of a site u can get a guide to wire up a v8 do u?
the lift kit,steering guard,dislocation cones,tyres and whatever else was on the discovery is going onto the 90 as the suspention is just totally rusted and will probably snap if driven hard so the lift kit is gin on as its brand new lol
as you said yes they are mine so i can break them if i want to ,i don know why people are so upset about me doing my day-to-day buissness
im not sure what the 90 was originally but i got brand new sides for it and a second hand roof as both wernt the best
yeh ur right it is a HIGH-LIFT not many people get that lol its only on like that tempory because i will get a proper holder and lock for it so it wont get nicked no matter how hard they try lol
does anyone know where i can get sum cheap second hand doors? needs to have windows and function properly i need a back door and both sides also a windscreen and the little corner windows on the sides? also needs to be CHEAP as im 14 and only got like £50 for sum parts
also "onefastsmoke" can you put ur pic onto paint and point out the switch? i cant really see anything different
pics of now broken discovery up in my next post
thanks
#22
Posted 26 December 2008 - 06:16 PM
twisting the mounts out of place
body off
body on floor
rolling chassis
V8 engine
body being crushed !
since the last pics the body has been totally flattend !
#23
Posted 26 December 2008 - 06:18 PM
its the black round switch in the middle allows you to disable brake lights, indicators etc. for when driving using infra red or in convoy
looking at changing my 2.5 NA diesel to v8 myself as well sometime next year for the wiring just get yourself a discovery or defender haynes manual with both engine diagrams in and try to put the two together, if your discovery is an efi then I would be tempted to ditch the injection and get some carbs from an older range rover then you'll have no need for an ecu etc.
very good luck with finding some good doors but I doubt you will get anything with that budget. good doors are like the holy grail to defender owners so usually go for silly money. depending on what your use is going to be I've seen some very rotten ones repaired by riveting on checker plate to the bottoms, I know its a bodge job but it is a solid one and cheap.
#24
Posted 26 December 2008 - 06:31 PM
it is interesing to learn about the way military veichles have theese switches and attachments tho as its good knowledge and also as im planning on bein a mechanic in the army so its usefull ! so thanks for that
iv checked the price of carbs and bits and they look at £700 for as good set,alsoyou then have to sort the mixture ect..and if you go up a steep bank and stall the fuel runs out of them so you cant restart which is why i cant understand why they use carbs in trials ! easier to change engines i supose lol
as for the doors im not botherd if they are defender doors or series,mine are not toatally rotten but have gone quite a bit and also thy are just bare doors there is nothing on them at allso need all that for windows ect....im looking more for series doors as i can then have sliding windows which are easier for my purpuse lol
can anyone make me a windscreen and the back windows out of perspex? or (anything that will fit ) its only tempory as it isent going on the road for a while yet! i will pay for it obv mind lol
#25
Posted 26 December 2008 - 08:33 PM
so whats your plans for the chassis?
Edited by gregh55, 26 December 2008 - 08:34 PM.
#26
Posted 26 December 2008 - 09:13 PM
don't worry too much about all singing and dancing carbs, standard ones do the job fine, early range rovers had either stromberg carbs or su carbs. just look for a complete su setup as these are better. seen loads go on ebay for around £25. when I used to have a range roverI changed from efi to su carbs and found a world of difference, never suffered from fuel starvation on steep inclines and after the initial setup never needed to touch the mixture again. they are generally used in trials etc because of their simplicity, efi = more electrics to get wet = more to go wrong. Oh and the noise from a carb fed v8 is much nicer as well
#27
Posted 26 December 2008 - 10:19 PM
I would say its fair to guess that its not ex-army going on that, especially if its missing the army rear cross member. Looks like a good solid look-a-like though. Most people wouldn't be able to tell the difference anyway, so I wouldn't worry too much!
Got to say for some one who is only 14 you have an incredible amount of know how, certainly more than I had at that age, and I suspect alot more than almost all other 14 year olds! Good work and good luck with the project(s)
#28
Posted 27 December 2008 - 12:01 AM
"the noise from a carb fed v8 is much nicer as well"
I AGREE WITH THAT ...
onefastsmoke: im looking into carbs but if im having them they will be the twins it would make it up a lost easier to stick the engine in yes,but at the moment i cant find any rangerover carbs iv been looking for ages,as for mixture ect... yes once its set up it will stay that way but the last V8 i did ( dads old rangerover a few years ago ) took me a longg time to set them up but i spose im better at mechanics nowadays i spose it would be worthwhile if i can find some as this engine is going to be in a lot of landroverss soon !
onlymelloyd:yeh i dont think its ex-army but its possibly bee nused somewhere in there as bits of it are noticeable as being from an ex-army landrover or its just had parts changed to make it look like it lol
"Got to say for some one who is only 14 you have an incredible amount of know how, certainly more than I had at that age, and I suspect alot more than almost all other 14 year olds! Good work and good luck with the project(s)"
<< also thanks for that not many people appricate that not all us younger kids are just yobbos getting p*ssed and drugged up on thee streets!
iv been a car/landrover nut since i was about 3 lol and has a 1st go at driving when i was 6 ( in a silver low-top mid wheel base 2.5 transit van that belonged to my dad lol )
the job im aiming for is a mechanic so i think iv had the right upbringing as i can now strip and rebuild preety much any veichle that im given
thanks
#29
Posted 27 December 2008 - 12:14 AM
i dont mind checker plate ontop of the wings to give them strength but devon 4x4s wings are completly out of checker plate lol
#30
Posted 27 December 2008 - 12:28 AM
Although I have to say, credit where it's due, you do seem to know what you're talking about and like me you keep yourself out of trouble!! I know a lot of people that don't, we seem to be a dying breed!!
I clearly know nothing about Landys though so Im gonna shut up and go to bed now |
