Broken Key In Petrol Cap
18 replies to this topic
#1 kopi
kopi
  • 116 posts
Posted 22 December 2008 - 10:57 AM
Title says it all. Anyone has a good idea on how i can fish the remaining key out of the key-hole? Or do I have to pry the entire fuel cap off?
Also, been looking at fuel caps at minispares, plminishop etc, prices range from 15 to a whopping 50+. Anyone knows if this would fit a 1992 Rover Spi fuel cap?
https://www.plminish...duct-A-CAP.html
Any other recommendations would help.
Thanks guys!
#2 miller 666
miller 666
  • 710 posts
Posted 22 December 2008 - 11:20 AM
well i wass going to suggest drilling it out but then u get *poop poop* in your tank, or empty your tank through the fuel pipe under the car and drill it out, take your tank out and put a tiny drop of petrol in it to swizz all the shaving round and tip it out the top. But thats a very long process.
#3 jonny-b
jonny-b
  • 189 posts
Posted 22 December 2008 - 11:30 AM
Would a locksmith be able to get it out? May be worth a phone call
#4 captainjack15
captainjack15
  • 3,925 posts
Posted 22 December 2008 - 01:24 PM
Could you try a put a flat head in there, turn it and then after if you get it removed drill it out and get a new barrel from some where like you suggested??
1p :wacko:
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 22 December 2008 - 01:50 PM
i think you will have to forcefully remove the cap, unless you can get a magnet to retract the broken bit?
forceful removal = huge pair of pliers / stilsons
#6 sweetser
sweetser
  • 3,995 posts
Posted 22 December 2008 - 02:59 PM
forceful removal = BFH
Fixed it for ya :wacko:
#7 Scotauto
Scotauto
  • 335 posts
Posted 22 December 2008 - 03:01 PM
wack a screwdriver in the key slot and turn it like the key. The broken bit should still function to unlock the mechanism. It's worked for me a couple of times
#8 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 22 December 2008 - 03:14 PM
Can you not get some plyers on the broken bit of key in the lock?
#9 kopi
kopi
  • 116 posts
Posted 22 December 2008 - 04:35 PM
Hi guys
i can actually still turn the fuel cap with the short stub on whats left of the key. I have spare keys, so just wondering if i can still salvage the cap or buy a new one.
#10 james962
james962
  • 2,677 posts
Posted 22 December 2008 - 04:41 PM
If you have a spare key and you can get the broken key out without damaging the cap itself, i don't see a problem why you couldn't use it again as long as it still functions properly.
I bought one from here http://www.minispare...d...&prod_id=98
#11 Ginger Baron
Ginger Baron
    Just On Tickover
  • 6 posts
Posted 22 December 2008 - 04:48 PM
I have had this problem as well getting most of the key out try a small paper clip or a small pin and try to bring it up out of the lock, its worked for me it just takes a bit of pqatience and practise.
#12 gsms
gsms
  • 2,285 posts
Posted 22 December 2008 - 07:27 PM
By the way the link in your first post is for a cover that goes over your original petrol cap. You still need a standard petrol cap either way.
#13 Scotauto
Scotauto
  • 335 posts
Posted 22 December 2008 - 08:15 PM
You could try welding a piece of metal carefully onto the broken key then pull it out.
#14 kopi
kopi
  • 116 posts
Posted 23 December 2008 - 03:29 AM
Thanks for the tip guys, will definitely have a go at fishing it out.
James962, there're 4 other petrol caps on that site you posted. Would any of the other non-locking caps work, or are those just covers that go on top of the original cap as well. http://www.minispare...p;sub_cat_id=33
Is there anywhere that sells a non-locking filler cap in its entirety. I'd like to avoid the issue of broken keys again especially since there aren't any petrol theives where I come from. =)
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 24 December 2008 - 12:26 AM
Well there's this black non-vented cap here: -
http://www.minispare...=... (non ven...
But I'd still prefer a lockable cap myself and so long as you keep it lubricated with some 3in1 or graphite powder, then that key shouldn't snap again: -
http://www.minispare.....KING STAINL...
>_<
