Anyone got a link or advice
Posted 20 December 2008 - 08:25 PM
Posted 20 December 2008 - 08:34 PM
Someone at work mentioned about using two nuts against each other to remove them? I need to get the old studs out from the head, Had a try but I give up I can't work out how its done!
Posted 20 December 2008 - 08:45 PM
using the first nut, you should be able to unscrew the stud.
Pete.
Posted 20 December 2008 - 08:50 PM
Edited by lrostoke, 20 December 2008 - 08:51 PM.
Posted 20 December 2008 - 08:57 PM
Posted 20 December 2008 - 09:01 PM
Posted 20 December 2008 - 09:03 PM
You are wedging the 2 nuts together, hopefully the friction on the threads in the top nut will be higher than that on the threads in the block, so they will unscrew instead. Make sure the threads are free of oil and add a 3rd nut if needs be, stop turning the bottom nut if it is pushing the upper nut(s) instead of removing the stud from the block - you'll strip the thread.
Posted 20 December 2008 - 09:17 PM
Posted 21 December 2008 - 07:15 PM
Posted 21 December 2008 - 07:58 PM
Posted 21 December 2008 - 09:01 PM
If it is then maybe a stickie in the faq's?
Posted 21 December 2008 - 09:06 PM
Posted 21 December 2008 - 10:00 PM
Posted 21 December 2008 - 10:58 PM
Just one thing and it might make no difference, but when tightening studs in I use the outside nut, not the inner one like you are doing.
And use the inner one to undo the stud.
