Replacement Starter Motors
Posted 20 December 2008 - 01:51 PM
has anyone ever used these starters?
http://www.powerlite-units.com/
just wondered if they really are much better than just buying another recon motor.
Posted 20 December 2008 - 02:26 PM
Posted 20 December 2008 - 03:02 PM
the orginal starter has a 10 tooth gear on it, the powerlite ones are available in 9 or 11 tooth.
Posted 20 December 2008 - 03:06 PM
Posted 20 December 2008 - 03:11 PM
Posted 20 December 2008 - 03:19 PM
Posted 20 December 2008 - 03:44 PM
cheers
Posted 20 December 2008 - 06:19 PM
Not worth it, unless it's a competition car looking to shave off every ounce of excess weight.
Beg to differ, if you have an Inertia starter, anything is better
Thoroughly recommend the gear reduction starters from Lynx AE best £140 I spent
Posted 23 December 2008 - 02:48 PM
not sure if £140 could be better spent elsewhere, recon inertia, new battery HT leads etc.
Posted 23 December 2008 - 10:53 PM
Change the ring gear and fit a new pre engaged starter if you cant afford the high torque motors
Posted 24 December 2008 - 11:55 AM
Cost is a little steep, but why replace a pants starter with an identical new pants starter?
good point. is it a mission to change the ring gear though?
also have pre-verto clutch and flywheel...?
Posted 24 December 2008 - 12:04 PM
I see no point in buy a £100 or so starter and a new ring gear.
If it ain't broken, don't fit it.
Posted 24 December 2008 - 12:06 PM
Posted 24 December 2008 - 01:59 PM
engine is in the car but it has no front end and no inner wings, can it be done in situ?
Posted 24 December 2008 - 02:06 PM
If you think your starter is a bit crap. Why replace it with something that will be equally crap? I thought this was the whole point of the topic.
Granted, perhaps, if you do not have a performance engine with high compression, the inertia starter will just about do the job, but in all other situation it is useless. Also consider why Astin Rover decided to bin the inertia for the pre engaged
but, if you are happy that is all that matters.
Ethel, if you think the inertia starter is noisey, you want to hear the raquet these gear reduction starters produce
