Rear Subframe
Posted 15 December 2008 - 01:22 PM
Cheers, Dan
Posted 15 December 2008 - 03:29 PM
rear subframe nuts and bolts some or all will be sized
rear radius are hand brake quadrants/pins and washers will be sized
rear radius arm sharft and bearings most likely worn
rear brake cylinders one or both will be sized
rear brake adjusters one or both will be sized
rear radius knuckle joint plastic cap may have gone
large rear sub bush mounting pin can give problems
rear wheel bearings check them while your there
rear brake shoes depends how long they have been in
hand brake cable should be ok
rear sub bushes should be ok
brake pipes should be ok
cone springs should be ok
new shocks well worth the money
jet wash and paint the whole boot floor
big can of WD
Posted 15 December 2008 - 04:39 PM
I have planned on taking it all apart to clean it, so will check for seized parts as i go. In terms of knuckle joints, is it worth replacing them? Read on here somewhere they're the most likely part to go in suspension terms?
Will be getting a new fitting kit for it also.
In terms of sealant, what is the best type? Waxoyl or Dinitrol (sp?) any other suggestions?
Cheers, Dan
Posted 16 December 2008 - 09:32 AM
I would kurust any bad bits then paint the whole boot floor the then go over with body schutz or waxoyl or under seal. don't go straight over with under seal alone i did and i am regreting it, it makes any rust worse. waxoyl is good but has little abrasion resistance best for cavitys, a friend of mine swears by painting then waxoyl even in cavitys.
frost do a cavity spray tube for spray cans.
Posted 16 December 2008 - 12:18 PM
All id say is buy a grinder and get the old subframe off the car. Then assess the situation.
I ended up having my old subframe with everything bolted to it on my garage floor then basically built up a new one next to it.
I think it depends on how much patience and time you have. I ended up decided i wasnt going to mess around trying to clean bits up and bolt new and old bits together, so did the lot. Plus i found that most bits are cheap.
I wire-brushed my heel board and boot foor, then gave it one hel;l of a coat of black underbody waxoyl. Ive got waxoyling let to do now everything is bolted back together. Im thinking of using the fefil can and spray gun halfords (or hell-frauds) sell.
My mate said his mk1 golf was waxoyled every year and was rust free from new with no bodywork replaced!!!! all original from 1988 or whatever. Thats what has persuaded me!
Posted 16 December 2008 - 02:03 PM
Neilos, When you say you replaced everything what do you mean? Radius arms, rubber cones etc? or things like the knuckle joints? ie. the cheaper stuff. Although obviously if anything is beyond use it'll have to be replaced anyway.
Can't check it now as im at uni, but i've got the whole xmas break to work on it, so should be in reasonable knick when its put onto the mini.
Posted 16 December 2008 - 06:11 PM
I put everything on there new, all new piping, handbrake cables, radius arms, pins, quadrants, cones, hi-lo's, knuckle joints, dampers, cups...etc.
All my original stuff was covered in oil, mud and *rubbish* and was all rusting and practically ceased. Plus i want to make my car to show standard so hence the job!
I sourced lots of bits on the net...etc so if you need any advice or whatever just ask.
The most expensive things on my list was the subframe, radius arms and pre-built brake assemblies. Everything else was pennies.
Posted 16 December 2008 - 06:30 PM
The subframe i took off...
The make over...
Posted 16 December 2008 - 06:36 PM
Posted 16 December 2008 - 06:47 PM
My pride and joy. I love this car to bits!!!
Nice car, where did you get the alloy subfame mounts from, i was telling a friend about them and not been able to find them.
Posted 16 December 2008 - 07:18 PM
Posted 16 December 2008 - 07:19 PM
[/quote]
I want some too!! Where from and how much??
Very tidy car by the way!
Posted 16 December 2008 - 07:36 PM
Cheers for the pics by the way, and thanks for the protection advice big_matt
still new to this, but best way to learn is to get involved right?!
EDIT: Just realised you posted answer just before the pictures.. got distracted.
Edited by Beddo88, 16 December 2008 - 09:04 PM.
Posted 16 December 2008 - 07:58 PM
Posted 18 December 2008 - 12:58 AM
