Supercharged 1275?
23 replies to this topic
#16 planejob
planejob
  • 37 posts
Posted 19 January 2014 - 06:44 PM
This is interesting.  I'm a newb, and I'm positioned on the wrong side of the ocean for parts availability, but I think this would be pretty amazing on my grey market Jap Spec re-vinned 1976/96 Mini.
Is it possible to fit a M45 within the confines of the bonnet and keep the A/C fitted?  I would imagine so, as the A/C is on the front and the M45 appears to go on the top/rear.    But in practice...
Also, turning the A/C off might just have the same effect as installing a supercharger.   :lol:
#17 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 19 January 2014 - 08:20 PM
You need to use a pump producing a high enough pressure & a proper nozzle to produce a very fine mist. The water needs to be properly atomised to mix with the incoming charge.
On a suck through it will have most benefit injecting it before the charger.
Phil.
And on passing through the combustion process it turns to steam?
#18 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 19 January 2014 - 09:57 PM
Yes mate.
#19 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 19 January 2014 - 10:19 PM
That's where the magic happens
#20 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 20 January 2014 - 09:30 AM
what sort of supercharger do you use and were could you source one from?
most use supercharger is the Eaton M45 from a MINI cooper S. You can source these in scrap yards and on ebay for around £200 or less.
Or you could use the M45 from a Merc, chop the end off and weld a plate on. It has the advantage of not having the water pump drive on the end, making the inlet lower down, and they're cheaper. I got mine for £100
Stu
This would also be good for keeping the inlet manifold at less of a angle causing the carb flooding after engine switch off.
You could also bring the carb closer to the charger if space is the same.
#21 M30
M30
  • 42 posts
Posted 20 January 2014 - 04:52 PM
Stu
I'm currently on with working through this conversion and the intention is to have the HIF 44 mounted directly to the end of the blower, this should do away with any carb/inlet manifold freezing issues, and also cool the blower at the same time without the need for water injection. When I get a bit further I will post some pics.
Stu
#22 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 20 January 2014 - 08:08 PM
You know the carb will be popping out the bonnet?
#23 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 20 January 2014 - 09:44 PM
Not if you use a sc12 :)
Untitled by g19asn, on Flickr
Edited by Gr4h4m, 20 January 2014 - 09:46 PM.
#24 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 21 January 2014 - 09:17 AM
He might get away with it as the intake is lower because of it not having a water pump on the end.
