Can anyone tell me the correct pressure for 165-60-R12's.
They are on Minilites I bought, but the pressures were all different, asked two garages and kwik fit say 26 and nationwide say 34 !
Matt
Correct Tyre Pressure For 165 60 R12's
Zacherius
, Dec 12 2008 12:26 PM
6 replies to this topic
Posted 12 December 2008 - 12:26 PM
Posted 12 December 2008 - 12:28 PM
28-30. I always do 28 but 34 is too much!!!!
Posted 12 December 2008 - 12:31 PM
Thanks for quick reply.
Matt
Matt
Posted 12 December 2008 - 12:56 PM
28 front, 26 rear is usually the best setup for me.
Posted 12 December 2008 - 03:26 PM
I set mine at 28psi front and 29psi rear.
Posted 12 December 2008 - 04:03 PM
a quick search of the forum would have provided you with an answer! please try to use the search before posting questions as you may find the answer without the need for a new thread
Posted 12 December 2008 - 05:44 PM
Whatever works best for you and your car really. You need pressures a little higher at the front because you have most of the weight there and the pressures a little lower at the rear to give you some grip as you've got very little weight at the back.
