sometime ago had an idea to corner weigh the mini, but did not want to pay much, so i though clutch cylinder/pressure gauge with a lever or bathroom scales, i'm gussing a mini could be upto 250kg on one front wheel, i could not find cheap scales that big until i found these for under £40.
myweigh 550xl from escales
read somewhere an imp owner may have tried these.
drive mini onto scales and 3 spacers the same height (37mm) might use small ramps too, read weight on one wheel at a time. add together for total car weight.
They are speak your weight so you can be sitting in the car and get that weight too.
only downer is to turn them on you have to apply a weight then remove, and they only stay on for 30sec.
I cross calibrated these in kg 'results only' see below.
ref reading
5.0 4.7
14.58 14.4
20 20
25.5 25.5
45.39 45.4
64.97 65.1
81.6 81.6
107.0 107.1
127.0 126.9
141.6 141.4
