Mpi Coil Pack
5 replies to this topic
#1 nicksuth
nicksuth
  • 1,631 posts
Posted 09 December 2008 - 04:32 PM
It may be my interpretation of the 2 documents but to me it looks like the Haynes Manual (photograph) contracdicts the Rover Workshop Manual (sketch).
Can someone confirm the correct configuration????????????
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 09 December 2008 - 08:25 PM
if you look close enough at the triangular strenghtening ribs around the fixing holes on the coil you will see the plug numbers there :strongsad:
You are right though the pic on the right is wrong
#3 nicksuth
nicksuth
  • 1,631 posts
Posted 09 December 2008 - 11:11 PM
Yeh, great isn't it, and that's from the Pukka Rover (RAVE) Workshop Manual CD !!!!!!!!!!!!
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 09 December 2008 - 11:39 PM
Just because its in the Pukka manual doesnt mean its right, just like if you buy something you have to assemble, that the picture on the front of the box is of the item correctly assembled :strongsad:
Ive seen mistakes in workshop manuals all over the place, and its nit just Rover :-
#5 tmsmini
tmsmini
  • 722 posts
  • Local Club: MOASF
Posted 11 December 2008 - 12:00 AM
Pardon the stupid question, but becuase of the wasted spark would it be possible to swap 2 and 4 or 1 and 3? Would the timing be off?
Terry
#6 Sprocket
Sprocket
  • 7,266 posts
Posted 11 December 2008 - 12:36 AM
Terry
No because the cylinders are paired 1/4 and 2/3. swaping 1 and 2 or 3 and 4 will cause a missfire and the od backfire will do nothing to change timing, just the firing order
