The two pipes go directly down into the bulkhead, the one on the left has come from the drier via a hose running under the scuttle.
The one on the right connects to the compressor.
Aircon1.jpg 455.4K
45 downloads
This shows the hose connecting to the drier.
Aircon2.jpg 374.21K
44 downloads
This shows the hose from pic 1 connecting to the compresor.The other hose connects to the aircon rad
Aircon3.jpg 454.83K
43 downloads
This shows the bracket for attaching the alternator to the head.It is bolted to the last two head bolts and can be adjusted side to side.
Aircon4.jpg 265.44K
36 downloads
This one I am trying to show how the drier is attached to the servo but cannot get a good pic of it (will try again on Tuesday)
The front hose from this connects to the aircon rad
Aircon5.jpg 785.35K
32 downloads
This is showing the position of the fan belt/aircon belt.I presume the compressor is attached using the redundant alternator bracket but Im not
sure.
Aircon6.jpg 805.63K
48 downloads
I havent shown the rad as it is in a different position to yours.I also noticed that there is no fan with your kit , poss wont need one due to
being front mounted ?
Hope these help but if you need pics showing anything else let me know
I will post pics of the interior bits on Tuesday as I will be removing the front cover to fit a heater cable
I know there will be some differences but it might help
Chris
Just remembered , Minisport classified have got some aircon bits in their warehouse clearance bits, in case you find you have some missing
If you go to Minisport website the link to the classified section is on the right hand side in a yellow box (i think)
Edited by mrslaphead, 07 December 2008 - 10:02 PM.
