Yeah they are the Vizard alloys. I've only ever seen 2 other sets. 1 on ebay that sold for £920
and another on a car at the London to Brighton. I love them.
Was thinking about cleaning everything up, but I'm not building a concours car, it's going to be driven whenever takes my fancy, rain, sleet or snow. I know that if I start getting everything spotless, I'll be scared of driving it, so as long as it's not caked in crap, and works, I'm happy.
On to today's update, it's been a bit of a mixed day!
First off, as you're probably all aware, it's damn cold!! This morning I wasn't sure if I could face a day freezing in the garage. Went out and got some brekkie, and popped into the local sports shop for some gloves. A quick job with the scissors and they were ready for work!
They made a big difference!
Today's plan was to fit the windows in the doors and door handles and linkages. I started on the drivers side. I've never done this before, but spent ages putting it together, cursing that a clip wouldn't go in, cursing even more when I forgot to fit a screw to the handle that actually opened the latch. After a load of hassle I finally got the drivers door finished. I then moved onto the window.
This followed in the same vain. Loads of cursing trying to get the winder mechanism to fit. When it was all in the window was hitting the frame. A bit of persuasion
sorted this out. Then came the trim along the bottom. For some reason the trim I had was about 3mm too long, so I had to cut a bit off. but I managed to scratch the door frame in the process. Finally though it was all fitted and working.
Then I looked at fitting the shut plate on the B pillar. Fitted it all up and it shuts fine, although the bottom of the door sticks out loads! I tried moving the plate around, and adjusting the door on the hinges and nothing has helped it. I even tried closing the door without the seal, and it still sticks out. I think my door might be a bit twisted? Hence why my window wouldn't close properly either. Any ideas?
Anyway, moved onto the passenger side lock and discovered something even more concerning! I tried bolting the handle to the doorskin, and the holes on the skin don't line up with the handle! I'm guessing it must be because it's a new heritage panel??????? Having found this little bombshell I decided to leave it for today, but I guess I'm going to have to carefully file out the holes so they line up. I'm also missing some bolts to to it properly, so instead I decided to tackle the window, and with what I learned by doing the drivers side, I did it in 10 minutes
Once I'd done this I fancied an easy job, so fitted the seam trim clips and seam trims. Makes a massive difference!
After this I'd pretty much had enough, so decided to leave it and have a tidy up in the garage and call it a day. Overall I'm pretty happy with today's progress, but would have liked both doors complete really.
Tomorrow I think I'll stay out of the cold, so I'm just planning to fit some bits to the bootlid and bonnet which are currently taking residence in my bedroom, much to the distaste of Mrs Scrippo!
