well today we hit another milestone in my mini rebuild! I finally managed to fit the engine. Well, it wasn't just me, I have to say a big thanks to my mate Dan who came round to give me a hand.
Decided to do the work outside the garage as it was a lovely day, and we'd have more space. I'm glad we did. The pic above shows the engine being lowered in. I'd highly recommend that this is a 2 person job, as Dan lowered or raised the hois as I manouvered the engine to avoid it banging the shell.
Getting lower in the bay..... nearly there. The photo was a chance to have a breather as it was pretty intense lowering the engine bit by bit making sure it didn't scratch itself or anything else!
Engine in! The lower mounts were a pain in the bum to get bolted in. I bought some supposedly easy fit mounts from a guy on ebay, who had welded on a couple of nuts. Well we cross threaded one, so out came the grinder to get it off. I recommend anyone fitting new mounts just go with the standard ones as it took 20 seconds to fit a nut and bolt! Once this was fitted it was wheels back on and off to KFC. I haven't connected the drive shafts yet but this should be straightforward, I just need to find out where I can buy the metal ties that secure the gaiters on, or whether cable ties will be OK.
So we decided to call it a day for the mini after lunch, so spent the afternoon playing kung fu panda on the xbox360, but when Dan left for home I couldn't resist getting back out in the garage!
Painted my manifold, also did the inlet.
Fitted the windscreen filet and rear window filet as my tool arrived today! A fiddly job but OK once I learned the technique and used some grease.
Another pic of the engine! Really chuffed with how it looks, I just hope it works!
Scrippo
