Stuck Cylinder Head
Posted 26 November 2008 - 04:14 PM
My mini cylinder head is stuck to my block. I've posted about this before, but have still had no joy. I've removed all the studs/nuts except one, at the front centre, which won't budge either. I've tried hitting it, persuading it, and it won't move. I've also tried carefully separating the head gasket form the metal with a scraper, and this had had no effect either.
Anyone have any ideas? I haven't got the correct tool to remove the studs, I managed without it for the others.
Cheers,
John
Posted 26 November 2008 - 04:18 PM
id have 20 people who dont have a clue telling me i shouldent do it because of yada yada.
Posted 26 November 2008 - 04:19 PM
Posted 26 November 2008 - 04:20 PM
Posted 26 November 2008 - 06:07 PM
Posted 26 November 2008 - 06:29 PM
Posted 26 November 2008 - 06:39 PM
Unless you remove ALL the studs/nuts the head ain't gonna come off is, have you tried a nut splitter? or cut the nut down one side then it will undo. Then with ALL the studs out have another go at getting the head off.......................................
Posted 26 November 2008 - 07:01 PM
Flying gears - Your method is a last ditch attempt I think! I'll try the others before I go down that route. Thanks though, I'll bear it in mind failing everything else.
Haven't tried the compression method, will give that a go. If that fails the I'll go blowtorch and WD40 route. Might use some WD40 to help the compression along a bit. Will also try lifting it carefully.
v21ash - I have removed the nut on the last stud, but not the stud itself. Every other stud came out.
Posted 26 November 2008 - 07:08 PM
Posted 26 November 2008 - 08:53 PM
Paul.
Posted 26 November 2008 - 09:55 PM
Posted 26 November 2008 - 10:01 PM
Make sure you brace the block against something as it might tip over if you hit it too hard.
Posted 26 November 2008 - 10:12 PM
Posted 27 November 2008 - 12:08 AM
Posted 27 November 2008 - 12:23 AM
Hope it works
Chris
