Yammy R6 Engine + Mini
12 replies to this topic
#1 fpsasm
fpsasm
  • 117 posts
  • Local Club: LCMOC
Posted 26 November 2008 - 11:49 AM
Hi, i want to put a yammy R6 engine in the front of a mini, but is it possible to keep the original gearbox and clutch rather then using the R6's gearbox and clutch..
by the way, are there any very very very quiet exhausts for a yammy R6 engine ?
#2 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 26 November 2008 - 12:14 PM
what like a mini gearbox on the R6 lump. be more specific please
#3 nathansminis
nathansminis
  • 584 posts
Posted 26 November 2008 - 12:35 PM
it says in the title: yammyenigne + mini gearbox ?
#4 maph2
maph2
  • 1,291 posts
Posted 26 November 2008 - 12:44 PM
doh... ;)
my answer is "most likely not", but anything is possible if you have the time and skill to fabricate a conversion kit. would rather keep the R6 box and fit an reverse motor or reverse box
have you spoken with Promotive?
Edited by maph2, 26 November 2008 - 12:45 PM.
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 26 November 2008 - 12:47 PM
Surely the engine torque and bhp will be excessive for the mini drop gears, clutch and the box itself.
#6 maph2
maph2
  • 1,291 posts
Posted 26 November 2008 - 04:01 PM
yup, and only 4 gears instead of 6. probably more hassle than going with off the shelf set ups available
#7 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 27 November 2008 - 02:24 PM
so 4 gears on a box only ever designed to take 34bhp, mated to a bike engine?
Or a six speeder squential box the engine comes with?
Is a tough choice i can see there.
unless you can fabricate your own bits then this is going to be very expensive and would not work IMO.
#8 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 27 November 2008 - 03:59 PM
I am wondering how you intended to remove the R6s gearbox, its casing is an integral part of the crank case so I should imagine it would be rather difficult? If it was at all possible, the cost of the huge amount of specialist machining needed would make the project a no-go IMHO.
#9 maph2
maph2
  • 1,291 posts
Posted 27 November 2008 - 04:16 PM
golf clap to you sir....
Edited by maph2, 27 November 2008 - 04:18 PM.
#10 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 27 November 2008 - 04:30 PM
+1 on the golfclap
#11 StaffordSi
StaffordSi
  • 125 posts
Posted 28 November 2008 - 10:24 AM
a stage 1 tuned 1275 is probably torquier than the r6 engine.
keep the 6 speeder, with the 4 speed box the car would be slow as hell
#12 Boomboy77
Boomboy77
  • 285 posts
  • Local Club: WSMOC
Posted 28 November 2008 - 01:08 PM
Bike engines dont produce as much torque as car engines, hence they rev like nut cases to make power!!
The standard mini gearbox is fitted to the 850 and 1275 engines, no difference except the turbo box has a bigger nose bearing.
#13 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 28 November 2008 - 07:43 PM
a standard 1275 has more torque than an R6
