Ultimate Mini Builder Dvd - 100bhp 1380 A-series Build
#16
Posted 23 December 2010 - 08:24 AM
#17
Posted 23 December 2010 - 09:09 AM
#18
Posted 23 December 2010 - 12:07 PM
#19
Posted 23 December 2010 - 12:38 PM
Anyone has a link to where I can get it from, sounds like i will be needing it in the future.
Complete with sample video..........may be cheaper elsewhere if you search:
http://www.minifilms...iesbuilder.html
#20
Posted 23 December 2010 - 01:04 PM
#21
Posted 23 December 2010 - 02:21 PM
#22
Posted 23 December 2010 - 08:35 PM
Looks like I'm going to be the one to slightly put the dampers on it. I would say yes a very useful"guide". The gearbox part was the most useful to me.I fealt that too many things were missing to actually know why the engine achieved the result and it wasnt aimed at the grass roots enthusiast. Certainly if you can afford to build to that spec you can afford the dvd. The biggest oversight was of the head.I expected him to be in there with his die grinder and chamber template and explaining why,but he just went and bought the most important item to get his 100 hp.The time spent refurbing a standard head should have been used on modifying one,we are building a non standard engine after all.We dont even know what size valves were fitted or the exhaust spec.The flywheel miraculously came off at some point!!Omega pistons are unaffordable too for alot of folk.I dont know how many hp a fan uses but it wasnt on.Did he re-profile a needle or was he lucky to just hit on one.Could be just me but I found myself asking as many questions as were answered.Havent watched it for 3 or 4 months but I'm now going to again to make sure I havent wrongly commented or overlooked any more gripes!.Hi
How good is this DVD "ULTIMATE MINI BUILDER DVD - 100BHP 1380 A-SERIES BUILD"? I have basic mechanical knowledge but I have not build an entire engine from scratch. Would this DVD be of any help?
Syed
#23
Posted 23 December 2010 - 11:00 PM
#24
Posted 23 December 2010 - 11:08 PM
Watching it on dvd was great as i hate reading books (do it for a living).
Its only 15 quid (or around) and it is over 3 hours of entertainment; especially watching the awkwardness of ian stent the presenter. who never actually listens to anything that is being said.
#25
Posted 23 December 2010 - 11:17 PM
#26
Posted 23 December 2010 - 11:27 PM
Its a very informative vid on a complete engine build, makes me wish i had a garage of the same size and was stocked with the same tools
Made me cringe a bit where the lad at swifttune was performing a bit of precision tuning on the timing, smack the dizzy with a hammer and a big screwdriver and shout out a number ! .. thank god for Megajolt is all i can say
#27
Posted 24 December 2010 - 01:32 AM
#28
Posted 24 December 2010 - 06:41 PM
1275 Metro block offset bored to 1380
SW5 Cam
1.5 roller rockers
New cam followers
Richard longman head .. this was the vague bit but i guess the usual skimmed/ported/polished 12G940
73.5mm Omega 7cc Dished pistons
Added steel center main strap
Reground 10.10, balanced and tuftrided crank
Rebuilt clutch with lightened fly and orange diaphragm
Uprated water/oil pump
Rebuilt HIF44
Alloy inlet
Kent cams duplex vernier timing gears
ARP bolts/studs
The gearbox was rebuilt but the only new things were a few shims/gaskets and a new diff pin.
Let me know if i missed anything and ill let you know.
#29
Posted 24 December 2010 - 07:10 PM
I would watch the dvd and also have the haynes manual (pale blue one) next to you when building
Edited by Pauly, 24 December 2010 - 07:11 PM.
#30
Posted 25 December 2010 - 04:58 PM
The main things to take away from the film is to keep everything clean, measure every component before fitting and to get it set up by someone who knows what they are doing. I set my 1380 up using the ignition timing that came with my Aldon dizzy and jetting for the 45 Weber from my old more mildly tuned 1380. Peter Baldwin managed to find another 24hp in the engine which makes the £140 I spent on two hours at his rolling road the most cost effective part of the tuning process.
Here's the spec that Minifilms e-mailed out not long after I ordered the DVD from their website:-
SPECIFICATION
BLOCK, CRANKSHAFT, CONRODS/PISTONS
Sent to Rob Walker Engineering for the following machining operations:
Offset rebore to 73.5mm
Replace cam bearings
Check mains housing and line bore/hone if necessary
Machine centre main cap for steel strap and supply strap and bolts
Skim top of block 0.025" (25 thou)
Drill and tap face of block of 11 stud head fixing
Remove core plugs, acid dip block to clean and fit new core plugs
Regrind crank 010/010
Tuftride crank
Remove and discard old pistons
Balance rods
Fit new pistons
Full dynamic balance of crankshaft and flywheel/clutch assembly.
CYLINDER HEAD
Richard Longman & Co modified GT7 exchange head (12G940 casting)
Unleaded valve seats
36mm inlets and 31mm exhaust valves
Bronze guides
Double valve springs
Fully ported and polished and checked on flow bench.
CAMSHAFT TRAIN
Swiftune SW5 profile by Kent Cams
Kent Cams vernier adjustable steel duplex timing gears
Kent Cams followers
Kent Cams oil pump
PISTONS
7cc offset bowl 73.5mm Omega pistons
Supplied by MED
FLYWHEEL/CLUTCH
MED road weight steel flywheel and backplate
AP rally spec plate and orange diaphragm
ROCKERS
Mini Spares 1.5 roller tipped rockers
CARBURETTOR
1 3/4 inch SU carb from donor Metro unit
Fully refurbished at Southern Carbs and Injection and fitted on their alloy inlet manifold
Contacts:
Rob Walker Engineering - 01608 645666
Richard Longman & Co (Sid) - 01202 486569
Swiftune (Nick Swift) - 01233 850843
Kent Cams (Andy Burns) - 01303 248666
MED (Steve Whitton) - 0116 2461641
Mini Spares - 01707 607700
Southern Carbs and Injection (Roy) - 020 8540 2723
Brise Auto-Electrical Systems (Tim Brise) - 01322 277622
We extend our sincere thanks to everyone!
Edited by pogie, 25 December 2010 - 05:00 PM.
