Push Rod Wont Go In?
Posted 15 November 2008 - 05:29 PM
Posted 15 November 2008 - 05:46 PM
did you jiggle the rods about before you lifted them out or just yoink them straight out.
Posted 15 November 2008 - 05:54 PM
and when i took them out they just pulled out no need to "jiggle" and/or tug them? thanks
Posted 15 November 2008 - 05:58 PM
Posted 15 November 2008 - 06:00 PM
i hope not because i am only doing the head gasket and i need to get it fixed
Posted 15 November 2008 - 06:02 PM
the wiggling of the push rods is not to help remove them but to make sure the cam followers drop down off the push rod
Posted 15 November 2008 - 06:04 PM
and cant i just push the push rod down and that will drop the follower...maybe (dont shout)
Posted 15 November 2008 - 06:07 PM
errrr areyou saying i will have to rebuid my engine?
No I was saying it was lucky I ws rebuiling it as I wouldn't have found them, its a simple fix like Bungle said, no need to worry, just makes changing the head gasket a bit longer lol.
Posted 15 November 2008 - 06:08 PM
it need to be the right way up and go down square
Posted 15 November 2008 - 06:09 PM
o ok will i justbe able to pull it down?
All it is, is like a little cup thing you just need to put it back in the hole, open side up, simple.
Edited by 1987_ParkLane, 15 November 2008 - 06:10 PM.
michael
Posted 15 November 2008 - 06:11 PM
ok thanks guys mucho appreciated
michael
No probs
Posted 15 November 2008 - 06:39 PM
if you had a 1275 engine you would be in the do do, always wiggle the push rods out
Posted 15 November 2008 - 06:56 PM
[attachment=74786:Cam_Foll...___Block.JPG]
