Dashboard Warning Light (!) Please Help
jsmith77
, Nov 09 2008 11:23 AM
8 replies to this topic
Posted 09 November 2008 - 11:23 AM
Cant find my mini handbook and have a RED WARNING LIGHT ON THE DASH.
It looks like an exclamation mark with a squiggle underneath it and (!) around it
Please could anyone let me know what this means ASAP
THANKS
THANKS
Posted 09 November 2008 - 11:43 AM
this is predomantly a classic mini forum, lucky for you i have a new mini too
Is it lighting up orange or red? theres too that look similar
Posted 09 November 2008 - 11:45 AM
Think it may be the handbrake warning light?
Posted 09 November 2008 - 11:47 AM
Its a red light (!) with a squiggle underneath
the handbrake one is without the squiggle this is not a handbrake light
Posted 09 November 2008 - 11:48 AM
yes, that light can mean that the fluid is low as well,
the other option is the flat tyre warning light
Posted 09 November 2008 - 11:52 AM
Also the flat tyre light lights up orange, i asume you have runflats on?
Worth checking you presures are correct i had a pucture in my run flat friday and i didnt even realise untill the dash light came on!
Ah just re-read your title and you say red warning light?
the only red ones with a ! is hand brake
Edited by insamoufonyx, 09 November 2008 - 11:54 AM.
This?
Usually indicates a problem with the brakes!!
Like insufficient amount of fluid caused by a leakage.
If it lights up you should:
- not drive it anymore
- inspect your brakes carefully for leakages
- especially the rear brake cylinders
If you can't find any leakage (rear cylinders must be completely DRY to be ok), check the wiring
You can push the switch to check if the warninglight in it is still working.
Regards,
Jan
Regards,
Jan
Posted 09 November 2008 - 12:00 PM
I have been told its a tyre pressure indicator
Posted 09 November 2008 - 05:09 PM
yep as i said before
