Door And Window Seals
stormintrooper
, Nov 01 2008 09:09 PM
10 replies to this topic
Posted 01 November 2008 - 09:09 PM
recently bought new door seals and rear side window selas but they do not fit, the door seal is about an inch too short on both doors and the window seals the bit that would fit onto the lip of the window frame is on the inside of the seal and yes i tried twisting it around but then found that the rubber seal was too big and would not fit, bought these from minispares if you need to know, any help or sugestions?
Posted 01 November 2008 - 09:15 PM
Door seals are meant to have a gap (bar I think MPi ones). Try to get the gap to line up with the drainage hole at the bottom of the door.
As for window seals, they are tight. I suggest taking the windows out (if we're on about rear opening ones) to make life simpler.
Posted 01 November 2008 - 09:41 PM
door selas have gaps in them built into the rubber but i literally mean the rubber seal is too short and they do not meat each other
and my opening windows were out but as i said, they were way too big and the wrong way round i.e. what i was on bout with the bit that would go around lip of window frame being on the inside of the rubber not outside
Posted 02 November 2008 - 12:27 AM
Your supposed to fit the rear window seals onto the car and knock them tight into all the corners and then trim it off half an inch overlap at the middle and put the end in and knock down for a tight fit.
Posted 02 November 2008 - 01:13 PM
ok so windows i hav to cut and trim but what about the door seals being too short
Posted 02 November 2008 - 03:36 PM
oh ok, i will give it a try, and the door seals were from minispares listed as MK3 onwards to 1991, seing as i have '89 i dont get why they dont fit, bout an inch short on both doors
Posted 02 November 2008 - 03:52 PM
I got my windows and door seals from minispares too - I think i may have have to cut the door seal but not much but the rear window was fine. You just have to force it into place.
And about them being the wrong way round - Your probably just putting it in the wrong window?
Posted 02 November 2008 - 03:57 PM
nah i got them on right, so any ideas about the door seals being too short, shall i just call them tomorrow and tell them that?
Posted 02 November 2008 - 04:32 PM
replacement door steps would effect the fit - see how the door sits without the seal, you may decide a bit of body modding would give a better fit. I'd also think there's a bit of stretch in the seals if needed.
Posted 03 November 2008 - 11:39 PM
well on both doors i had a section of door step cut out and matched with an exact same size piece to weld in, also i have noticed now that the passenger door now (only slightly) hits the door frame above the the thing that the door locks to, not badly but enuf that its scratched my new paint
i will try stretching the dor seals
is there any way of shifting the door back up to stop it hitting the frame?
Posted 04 November 2008 - 06:33 PM
The door seals now fit and still havent gotten round to using a rubber mallet for rear seals
but i am still concerned about the passenger door sagging and hitting the door frame
