Lightweight Z18Xe
#1381
Posted 01 February 2011 - 10:22 PM
#1382
Posted 02 February 2011 - 04:21 AM
Going to investigate the engine knocking more tomorrow. It sounds expensive, and im actualy skint now.
I took this video to help the lads on Turbo minis help me identify it.
h7s-y93ddyM
Sounds like a rattly old transit. I've also got to bleed the clutch again, I don't think it's sealed properly.
I can get a driving vid of it if anyone's interested.
#1383
Posted 02 February 2011 - 09:02 PM
Still can't work out the knocking, maybe cam bearings, not sure and can't tell without a strip down.
Ben
#1384
Posted 02 February 2011 - 09:53 PM
#1385
Posted 03 February 2011 - 01:47 PM
#1386
Posted 03 February 2011 - 01:59 PM
I picked up the drops from the post office today, came back to the postman with this for me.
#1387
Posted 03 February 2011 - 04:58 PM
dean
#1388
Posted 03 February 2011 - 05:35 PM
#1389
Posted 03 February 2011 - 05:38 PM
Some nice parts there mate!. Trigger wheel looks solid as *******!. Are you going to make the sensor adjustable?
Cheers man, yeah that trigger wheel should do the job nicely. Im still unsure about the sensor bracket, I havn't started work on it yet. I'll have to see when I start making it.
You got a pic of when you had yours? just for some ideas. I just popped out to get some vaccum line, not sure if it's the right I.D, but will have to see when I start fitting it up.
#1390
Posted 03 February 2011 - 05:41 PM
I'll get a decent pic for you of my setup as the engine sits in the shed!.
#1391
Posted 03 February 2011 - 05:45 PM
Got a load of 6mm pneumatic pipe here you could of had man!. Fits the MJ Perfectly, and theres loads of fitting available.
Is that 6mm OD or ID? I thought it was more like 3mm ID.
#1392
Posted 04 February 2011 - 08:31 PM
The sensor is slightly adjustable, but I got it as close as I could by cutting a new keyway in the pulley, then offset the VR sensor in the MJ software.
#1393
Posted 04 February 2011 - 10:34 PM
#1394
Posted 04 February 2011 - 10:38 PM
#1395
Posted 04 February 2011 - 10:39 PM
yum yum!
