All the drop gear clearances fine? Even Idler?
Yup, idler gear is 0.005" end float. Can't remember primary, but was within tolerance.
Posted 30 July 2010 - 03:27 PM
Posted 30 July 2010 - 03:29 PM
Posted 30 July 2010 - 03:32 PM
I'd say its either drop gears, clutch/flywheel or the release bearing?
Posted 30 July 2010 - 03:42 PM
Posted 30 July 2010 - 03:48 PM
Primary thrust washer OK? Whats the crank endfloat?
Posted 30 July 2010 - 03:50 PM
Posted 30 July 2010 - 03:51 PM
Might be a gearbox issue? How about jacking the front up and trying all gears quickly?
Posted 30 July 2010 - 03:54 PM
Posted 31 July 2010 - 10:14 PM
Posted 31 July 2010 - 10:28 PM
Posted 31 July 2010 - 10:29 PM
998 in then?
Posted 31 July 2010 - 10:30 PM
Posted 31 July 2010 - 10:33 PM
I'm sure i've got one if you need it in a hurry.
At least it gives you time to investigate the engine properly
Posted 31 July 2010 - 10:35 PM
Posted 31 July 2010 - 10:39 PM
Might not be the most suited carb but at least the engine will run??
