did u check or change the needle roller bearing in the housing when u had it all apart?Dean
They appeard ok, I checked them and seemed to be fine.
Posted 30 July 2010 - 02:20 PM
Posted 30 July 2010 - 02:41 PM
Posted 30 July 2010 - 02:42 PM
Posted 30 July 2010 - 02:47 PM
Posted 30 July 2010 - 02:48 PM
Posted 30 July 2010 - 02:52 PM
Do you have another transfer case you could swap it with to check the bearings inside that? Saves pulling and fitting new bearings in the one you have that's all.
Posted 30 July 2010 - 02:53 PM
Posted 30 July 2010 - 02:54 PM
If i lived closer you could have borrowed one of mine. Shame. Is there anyone locally who might have one?
Posted 30 July 2010 - 02:55 PM
verto clutch and flywheel?
Posted 30 July 2010 - 02:56 PM
Posted 30 July 2010 - 02:57 PM
I had a similar noise on one of my old cars.
The verto clutch/flywheel was damaged. a couple of bolts had come loose in the clutch/flywheel setup.
Jordie
Posted 30 July 2010 - 03:01 PM
Posted 30 July 2010 - 03:07 PM
You can see the bolts and the damaged centre piece.
It sounded just like your video, but if you've checked it then I guess its not that. hope you find and fix the problem soon.
Jordie
Posted 30 July 2010 - 03:22 PM
