Lightweight Z18Xe
1943 replies to this topic
#931 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 24 June 2010 - 10:38 AM
Carbon doors? Polycarb windows? Loose the bumpers and bumper seams? Carbon grille, drilled of course. Carbon mirrors? Motorbike battery, Carbon Headlight rings, window winding mechanism is really heavy. Just some ideas?
All of that costs money, but yeah looking to do those things in the future.
Take a look at every part of the car no matter how small, 10%ish of its weight should be able to be removed or if possible refabricate in a lighter material to save around 50% of its weight. It takes time though, Ive spent 10 years getting around 230kg off my Sprint. Its currently around 420kg, I reckon with some carbon fibre it could go down to around 385kg giving close to 400bhp per ton
Yeah, your sprint has inspired me to go lighter.
400hp per ton? Thats truely awsome.
Although it has to be remembered this is my everyday car, and still has to be useable to go down to the shops.
Im hoping to be able to do a 16 second 1/4 mile with it at MITP.
#932 CaptainBland08
CaptainBland08
  • 675 posts
Posted 28 June 2010 - 12:49 PM
just noticed in your video ben... theres alot of gear crunching by the sounds of it??? :S
#933 mini_mad69
mini_mad69
  • 5,417 posts
Posted 28 June 2010 - 09:49 PM
2nd gear syncro is gone, normal driving you don't notice it.
Changing down is the worst.
#934 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 28 June 2010 - 10:05 PM
You can lose a lot of the doors with a grinder / holesaws if you put the effort in. If you have the tools you could maybe make up some CF/ alloy A panels.
And by the way, we have one odd FG doorskin here thats never gonna get used if you're interested in it?
#935 mini_mad69
mini_mad69
  • 5,417 posts
Posted 28 June 2010 - 10:16 PM
I started with the holesaw, but it was a rubbish one. Will try again with the bosch ones you recomended.
I'll keep going with the weight loss, i've been trying to get loads done recently, but keep getting distracted by things.
Will loose 2kg tomorrow, I promise.
#936 HARBER07
HARBER07
  • 4,498 posts
Posted 28 June 2010 - 10:19 PM
:cry: Good man! The Bosch ones seem really good to me. Drilled through 6mm plate at home and a 9mm girder at work with them!
#937 CaptainBland08
CaptainBland08
  • 675 posts
Posted 29 June 2010 - 11:25 AM
as for loosing weight on the doors... have a look at camp freddy's doors on ratty... he took a fair old amount of metal from the inside of the door...
Chris
#938 mini_mad69
mini_mad69
  • 5,417 posts
Posted 11 July 2010 - 09:37 PM
Mocked up on a 998.
Still on the fence wether this lot will be going in the car.
Ben
#939 HARBER07
HARBER07
  • 4,498 posts
Posted 11 July 2010 - 09:41 PM
I can tell your thinking twice about it :).
I've just lost a crap load from a door. Still uses glass wind up windows. Don't know how much though :)
#940 mini_mad69
mini_mad69
  • 5,417 posts
Posted 11 July 2010 - 09:44 PM
That lot weighs a ton though!
I have also been refurbing a vented 4 pot setup.
It all weighs loads!
Money is slowing me down at the moment though.
#941 mini_mad69
mini_mad69
  • 5,417 posts
Posted 12 July 2010 - 05:32 PM
c8W_htHEe0g
You can hear a bad noise when off the clutch. Hoping it's clutch release bearing.
#942 HARBER07
HARBER07
  • 4,498 posts
Posted 12 July 2010 - 05:37 PM
Its more likely to be the release bearing when on clutch from experience (as in pedal down). Is it the rattling noise or the squeaking you're on about?
#943 mini_mad69
mini_mad69
  • 5,417 posts
Posted 12 July 2010 - 05:46 PM
Rattling/banging
The squeeking is the exhaust.
When I push the clutch down it goes away.
#944 HARBER07
HARBER07
  • 4,498 posts
Posted 12 July 2010 - 06:15 PM
I'm thinking drop gears to be honest. Does it make the noise when accelerating?
#945 mini_mad69
mini_mad69
  • 5,417 posts
Posted 12 July 2010 - 06:32 PM
All the time unless the clutch pedal is down.
I've never looked or thought twice about a release bearing so no idea what they're meant to be like, so will wait for my old man to come home and have a look.
Crank end float is fine aswell. So im pretty sure whatever the problem, it's going to be in the flywheel area. The clutch pedal action was not smooth either but is now i've taken the slave cylinder off. Oil preassure was normal aswell, so im pretty sure it's not bottom end knock as that would probably show up in low oil preasure.
So im thinking it's release bearing or flywheel problem.
I want to spend around £2k on this car before end of summer.
