Lightweight Z18Xe
1943 replies to this topic
#841 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 07 June 2010 - 04:58 PM
great topic, just wondering how you cleaned the rest of the sound proofing off the floor? ive chipped all of it off just the rubishy bits left
Thanks mate, a flat thin scraper like you use to get off wall paper, that gets off most of the little bits. Then white spirit or similar to remove the gloop that's left.
I used petrol, but you have to be carefull.
#842 mini_mad69
mini_mad69
  • 5,417 posts
Posted 07 June 2010 - 09:41 PM
Engine in, it took longer because I kept getting distracted by things.
Made a nicer rad bracket, the other one was pitted, and rubbish. Also, steal is too heavy!!! :(
You can't realy see it, but the heater pipes infront of the rocker box have been stripped and polished, and the crappy black plastic joiner removed and a nice shiney blue one fitted. The engine is about fitted, but it wouldn't start. I have no idea why though, I think I flooded it. Will try with a fully charged battery tomorrow.
Ben
#843 CaptainBland08
CaptainBland08
  • 675 posts
Posted 07 June 2010 - 09:43 PM
good stuff :(
back on track now eh?
#844 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 07 June 2010 - 11:24 PM
Glad to hear you sorted the siezed engine mate. Don't sell the turbo bits. You'll regret it.
#845 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 07 June 2010 - 11:29 PM
Looking better ben!
#846 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 June 2010 - 12:18 PM
CHeers guys.
But it just won't start!
#847 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 08 June 2010 - 01:07 PM
Are you sure the cam didn't move when you did the chain?
#848 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 June 2010 - 01:17 PM
Pretty sure. Although if nothing else works I'll have to check it, I'll take the rocker box off and see what the valves are doing at tdc.
#849 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 June 2010 - 02:00 PM
5WMLhQ0arZo
At TDC, both valves are shut on cylinder 1. Cam timing seems fine.
#850 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 08 June 2010 - 05:22 PM
Got a strobe? Check timing.
Any chance you knocked the dizzy on taking the engine out twice, and rotated it a bit?
Try twisting the dizzy a smidge in either direction, whilst turning it over, see if it makes a difference.
And check the points and condensor.
Then, if it comes to it, strip and blast the carb.
With all the problems you've been having, i'd expect you to be used to a non-starting mini, i know i am!
#851 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 June 2010 - 05:31 PM
I did play with the dizzy and got it running a bit. But I KNEW that I didn't move the dizzy, so something else wasn't right.
Im a nob. That's out by 2 teeth! amazed it stayed in one piece let alone ran like that!
I realy need to stop dicking around and concentrate.
#852 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 08 June 2010 - 05:36 PM
Wooooaaaah! Slight oversight there, lucky you didn't lose a lot of valves... :lol:
#853 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 08 June 2010 - 06:28 PM
Bloody. Hopefully it's just a close shave mate and nothing has smacked into anthing. Didn't sound like it had anything hitting something so i'd guess it should be okay.
At least you've found the problem now :lol:.
#854 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 June 2010 - 08:49 PM
Yeah, it runs ok now.
Lot's left to do though.
#855 EatSleepJDM
EatSleepJDM
    previously known as 88minicity
  • 631 posts
  • Local Club: Blakehill Minis
Posted 08 June 2010 - 09:09 PM
my favourite mini on the whole mini scene mate, always loved it!
Keep up the good work
