Lightweight Z18Xe
1943 replies to this topic
#796 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 20 May 2010 - 05:21 PM
What can you do with the Iphone?
Nothing lol, but only got the money to buy i-phone or an ecu, so If I don't get an I-phone I'll buy the ecu.
Then sell my current phone and buy an ecu with that money.
#797 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 20 May 2010 - 05:25 PM
Ah, I thought there may be some funky app or something which is why you want one ;)
#798 mini_mad69
mini_mad69
  • 5,417 posts
Don't know, there might be.
#799 mini_mad69
mini_mad69
  • 5,417 posts
Posted 20 May 2010 - 06:53 PM
Well I don't have an ECU ;)
#800 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 20 May 2010 - 07:47 PM
#801 miniJJ
miniJJ
  • 262 posts
Posted 20 May 2010 - 08:04 PM
What sequential shifter did you get out of interest?
hey
I went for this one
http://www.autosport...uster-p-38.html
I have one of them too, it's amazing in the dark when you go through the revs! I love my megajolt (although had a nighmare with some faulty ht leads the other day). Running cushty now.
Love this car, keep it up! JJ
#802 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 20 May 2010 - 09:51 PM
hey
I went for this one
Hee hee yes you did!!
wish i had suggested HT leads...it did still sound like Coil or Module had gone...at least you have a spare now!! :D
got to say though there are loads of minis running MJ now, or in the process of going that way...amazing as 2 years ago it was barely heard of!
#803 mini_mad69
mini_mad69
  • 5,417 posts
Posted 30 May 2010 - 07:54 PM
Clutch started to slip today, only in 4th, but will soon work it's way through all of them, so taking it steady at the moment.
It's hemorrhaging oil at the moment aswell.
So engine will come out, new gaskets and sealent all round. Metro turbo clutch plate will go in. I might put a new gearbox on aswell, not sure yet, mine jumps out of 1st.
Weld up old seat mount holes. Re-weld the wing to the front panel, repair the front arch.
Re-wire all the accessories as there a mess at the moment. Sound proofing off the rear of the floor.
Attempt to remove dent in boot, and respray and hammerite the bit's that need doing.
Oh and all has to be completed by thursday. Also with no money.............at all.
Should be interesting.
Turbo conversion is moving further and further away at the moment, considering leaving it now, just keep running the 1380 as it is.
Hmmmmm lot's to think about.
#804 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 30 May 2010 - 08:12 PM
Will catch up with you at MITP Ben, glad to see its still giving you problems! :)
All good fun eh!
#805 mini_mad69
mini_mad69
  • 5,417 posts
Posted 30 May 2010 - 10:24 PM
Engine almost ready to come out, and sound proofing off.
#806 mini_mad69
mini_mad69
  • 5,417 posts
Posted 31 May 2010 - 10:46 PM
Oil leak found.
Clutch has oil on it, so new crank oil seal to go on, and hopefully no more slip.
#807 HARBER07
HARBER07
  • 4,498 posts
Posted 31 May 2010 - 11:22 PM
:unsure: Is that bogroll in the car at all times for brown trouser moments??
Big respect for sticking with this Ben :( . Can't believe all these problems you keep having :) :proud:
Edited by HARBER07, 31 May 2010 - 11:23 PM.
#808 mini_mad69
mini_mad69
  • 5,417 posts
Posted 01 June 2010 - 11:12 AM
I actualy have no idea why there is bogroll in there, I found it under the rear bench, I think that's for passengers when im using the loud pedal.
To be fair, the recent problems I think have been my fault rushing things. The engine has leaked oil ever since I last put the engine in, so I must have put that half moon gearbox seal in wrong, as it wouldn't move like that under use. I have no idea why the crank oil seal is leaking, maybe due to not fitting correctly when sliding the drop gear housing, I don't have the correct tool to protect the seal, so use insulation tape over the splines, which has worked fine loads of times in the past.
Had a look through all my spares here today, i've got a gasket set, but doesn't have a timing cover gasket, or a clutch oil seal. The local mini specialist is closed today, so will get the last bits tomorrow and put the engine back in.
I'll probably re-wire it today and do some welding and painting. When under the car yesterday I found the extent of the oil leak, it was dripping off the rear valance, drums are wet with oil, and the floors won't rust anytime soon.
#809 HARBER07
HARBER07
  • 4,498 posts
Posted 01 June 2010 - 11:28 AM
Just a thought about your breather setup - is it connected to the carb? Maybe too much pressure in the crankcase so its blowing seals out?
I must admit I've only ever slid the crank seal over the primary gear and knocked it on square and its never failed yet.
#810 mini_mad69
mini_mad69
  • 5,417 posts
Posted 01 June 2010 - 02:56 PM
No the breathers arn't connected, if I can make some room in the engine bay, I'll refit my home made oil catch tank, and then connect that too the carb.
I don't think it blew the seal out, I think it was just poor fitment.
You could be onto something with the crankcase preasure though, I'll look into it.
The engine came off the box, and is now back on and the gaskets and seals seem to have sat properly this time. So will bolt it up and get the new oil seal tomorrow, and refit.
Realy don't want to do anything on it though, I've got man flu.
