Lightweight Z18Xe
1943 replies to this topic
#601 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 23 December 2009 - 03:48 PM
Just a quick photoshop, seeing if my white details would look better in another colour. But I think they'll go white.
Did some worthwhile work on the mini today.
Removed the thermostat with holes in. Tested a load of other thermostats which didn't realy open properly, and the only one which operated properly was the one with holes in. So riveted them closed leaving one as a bypass.
It still didn't realy get up to temp, so took it back out and riveted the last hole shut. It now runs at aroun 75 degrees which will do for me.
Cleaned my ignition leads as mine were stinking and it started to splutter when I flew through a flood earlier.
Snowy mini :)
Thats all the snow I've had.
Frozen mini
Riveting
Clean plug leads, drove into a flood at around 40 and not even a splutter. Banging.
Now I might go reset the plug gaps to help it starting or paint my minilites.
Oh oh I fixed the electrical problem! Cleaned the alternator terminals and it works!! no more dim glowing charge lights. Yippeeeeeee
#602 Mi-Cool
Mi-Cool
  • 41 posts
Posted 23 December 2009 - 07:53 PM
Just read through the entire thread, god knows how much of my life is now gone :)
Was interested because my mini is the exact same colour with the same white chequered roof and after seeing yours, im definitely going to have my arches sprayed white :xmas:
Glad to see everythings finally starting to come together for you, keep it up :dontgetit:
#603 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,720 posts
  • Name: Chris
  • Local Club: None
Posted 23 December 2009 - 08:04 PM
hi im a noob when it comes to engines etc.
im just wondering how your heater works with the pipes plumbed through your inlet manifold?
CHeers
YetI
#604 Burnard
Burnard
  • 3,350 posts
Posted 23 December 2009 - 09:43 PM
Mine goes through my inlet manifold, and the heater still works as it did before plumbing it, so no change. also noticed the engine runs better with it plumbed in. (i ran it unplumbed for a bit after fitting the stage one).
your cars looking allot better than when i last saw it ben, keep it up :)
#605 mini_mad69
mini_mad69
  • 5,417 posts
Posted 23 December 2009 - 09:48 PM
What with a cylinder head attatched? ha ha ha
Such a pikey way of changing a gasket and it's still going strong!! :xmas:
#606 Burnard
Burnard
  • 3,350 posts
Posted 23 December 2009 - 09:54 PM
your cars looking allot better than when i last saw it ben, keep it up :xmas:
Such a pikey way of changing a gasket and it's still going strong!! :dontgetit:
:dontgetit: thats exactly what i ment.
Its not a pikey way, its the mans way! :)
#607 yeti21586
yeti21586
  • 3,720 posts
  • Name: Chris
  • Local Club: None
Posted 23 December 2009 - 09:58 PM
my heater bit has a wire comming outta it (and looks like a mini) so how would i do that setup with it???
#608 Burnard
Burnard
  • 3,350 posts
Posted 23 December 2009 - 10:04 PM
Do you mean your valve is bolted to the head like on all pre 1988 mini's? If so i will get a picture of my setup for you.
#609 yeti21586
yeti21586
  • 3,720 posts
  • Name: Chris
  • Local Club: None
Posted 23 December 2009 - 10:06 PM
yeah its a 79 so it is.
#610 mini_mad69
mini_mad69
  • 5,417 posts
Posted 23 December 2009 - 10:07 PM
You could go the other way, im assuming you have the small valve.
I removed the valve and just fitted a cylinder head take off, like this:
You could then run the pipe down the o/s of the engine into the manifold then out of the other side into the cabin.
I used to run a single piece of rubber hose from my take off like above but that always rubbed against the bonnet and wasn't very neat. The solid pipes on my car are off cuts of copper pipe after a bit of plumbing done in the house. I then primed and sprayed them, with a bit more time, I would have made it one piece.
#611 yeti21586
yeti21586
  • 3,720 posts
  • Name: Chris
  • Local Club: None
Posted 23 December 2009 - 10:28 PM
but how do i use the heater valve??
#612 mini_mad69
mini_mad69
  • 5,417 posts
Posted 23 December 2009 - 10:33 PM
That's my point of removing the valve and just having the take off.
I never used the valve anyway, only reason I ever turned the heater on was for warm air, why would I want it to blow cold?
SO removed the valve so that hot water would always pass through the manifold. This meant, that I turn the switch for the heater and hot air would come out.
I did have the valve at one point and the heated manifold and that meant that when set to cold the car did not run as smoothly as it did when the manifold was hot as the car had been tuned with the manfoild hot.
#613 yeti21586
yeti21586
  • 3,720 posts
  • Name: Chris
  • Local Club: None
Posted 23 December 2009 - 10:39 PM
thats a very good poin lol if i need cold air i shall open a window lol
cheers i shall stop hijacking your project thread which looks amazing by the way
YetI
#614 Burnard
Burnard
  • 3,350 posts
Posted 23 December 2009 - 11:16 PM
just decided to actually read your project thread :)
I dont suppose you have any 998 heads lieing about that you wouldn't mind getting rid off? :xmas:
#615 mini_mad69
mini_mad69
  • 5,417 posts
Posted 23 December 2009 - 11:29 PM
Yup, I've got 2!
