Lightweight Z18Xe
#421
Posted 03 September 2009 - 10:44 AM
People seem to slate gmax so im expecting a fair difference!
#422
Posted 04 September 2009 - 01:10 AM
So will try sort out the new bonnet tomorrow, maybe respray the rear arches. Carphone warehouse still havn't given me back my phone though, so still now pictures. Still have a little oil leak, but just going too have too live with it for now.
My inlet mods seem to have given me more low down torque aswell.
Does anyone know how thick the glass on the side windows is? I want too replace them with polycarbonate alternatives, too try bring some weight down.
As now I have a very heavy mini.
Ben
#423
Posted 04 September 2009 - 06:30 PM
Ben
#424
Posted 05 September 2009 - 09:42 AM
#425
Posted 05 September 2009 - 09:43 AM
#426
Posted 05 September 2009 - 10:52 AM
Perpex isn't that safe IIRC it shatters into large splintersbut you can just use 5mm perspex which is arond £30 a sheet
#427
Posted 06 September 2009 - 04:10 PM
im going to be useing 5mm macrolon perspex fitted into the origanal rubbers ive done this to a few of my freinds minis and a calone capri and works really well ive even managed to get the curve in the mini rear window so you dont get the horrible noise of the window vibrating hope this helps dan
ill add macrolon isnt cheep £130 a sheet but you can just use 5mm perspex which is arond £30 a sheet
Thanks for that, I was more looking at polycarbonate.
Yeah, was looking into polycarbonate. Very strong, they even use it in riot sheilds. Although when ever I say it people usualy go .
I know the fella who built la *woman of ill repute* the mini and la *woman of ill repute* 2 the trailer used tinted stuff in the trailer. I was going too use some light smoked stuff for cheap/easy window tinting.
#428
Posted 07 September 2009 - 09:31 PM
Today I bought a big money tin. It will be called the turbo fund. I desperatly want boost now. And turbo seems the better way too go about it.
Edited by mini_mad69, 08 September 2009 - 12:01 AM.
#429
Posted 08 September 2009 - 11:26 AM
#430
Posted 08 September 2009 - 03:23 PM
Are you planning to add the turbo in this rebuild, or at a later date?
Been watching this project since i joined the board, it's certainly been a roller coaster... Good luck with the rebuild mate.
Cheers, Paul.
#431
Posted 08 September 2009 - 04:09 PM
#432
Posted 08 September 2009 - 09:21 PM
Chriiiiiiiiiist! Unlucky mate, gutted to hear it =[
Cheers, Paul.
Not sure, I could mock up the turbo setup on this engine, but it's got high compression and I don't realy want too melt the powermax pistons in it. This engine is realy not meant for boost. Maybe low preasure, 4 or 5 psi.
jesus ben your beating my bad luck hahaha
Well, my fault I should have changed the crank when the flywheel came off in the first place.
I've got a few cranks on the cards at the moment, although it may be possible too get a whole 1275 that needs a rebuild. I will take the crank for that and then track down another one for that and build it into a turbo.
I just need too track down some turbo bits now.
Ben
#433
Posted 09 September 2009 - 11:54 AM
#434
Posted 09 September 2009 - 01:39 PM
Thats a really nice project you have there mate, it looks great, i really like the water bottle idea, do you mind telling me where abouts you got your ignition leads from and also where did you get your dash from? Thanks in advance George.
Thanks mate, ignition leads were off a classic car ebay shop, I would look it up for you but it was a while ago and would have timed out.
The dash also came from an ebay shop after the one I ordered from minispares didn't turn up.
Sorry I can't be any more help.
I just collected a short 1275 engine. I will use the crank to repair the 1380.
Then this engine will be the base for the turbo engine. Unfortunatly I will probably only be using the block from it, as the rest wouldn't be suitable.
Ben
#435
Posted 10 September 2009 - 04:20 PM
Just need all new shells for it, and then all the gaskets.
Then track down the crank and pistons too build the turbo engine. I have 2 good pistons but need too find another 2 for it.
