Lightweight Z18Xe
#406
Posted 29 August 2009 - 05:15 PM
#407
Posted 29 August 2009 - 05:50 PM
Hope you get it sorted this time
J
#408
Posted 30 August 2009 - 10:31 AM
Only thing Is I have no idea whats wrong with it, so don't know what too look for when it's apart. And the only way I can test it is by putting it back in the car
#409
Posted 30 August 2009 - 04:57 PM
SO took the engine out AGAIN! the flywheel was 180 degrees out so the stepped washer didn't torque it down properly
Feel a little silly now. Hopefully that'll be it sorted now and be back on the road. I do get the feeling that something else is up with it though. It can't be that simple.
Oh and the crank tail is pretty knackered now, so im going too see if I can find a knackered 1275 and get the crank out of it. Then do an engine rebuild on it.
Ben
#410
Posted 30 August 2009 - 05:35 PM
dan
#411
Posted 30 August 2009 - 05:39 PM
Jordie
#412
Posted 31 August 2009 - 12:43 AM
Im now tempted down the forced induction route. I've got pretty handy with the MIG welder so, a bulkhead box should be no problem.
I just need to find a suitable donor engine now.
Im going too wait for my new engine mounts too arrive before I refit the engine, so tomorrow Im going too clean, paint the head and do a little wiring tidying, as you can see in previous picutures, its a bit of mess under the bonnet.
I've also got too fill, re-inforce and paint my new bonnet, fit up some new mounting plates for the dzus fastners, and respray/fill the front end from all the damage. I just wish I could have some help, my old man has decided i Know minis better than him, so doesn't help me at all, and all my mates realy don't want too, because im working on it so often.
Ben
#413
Posted 31 August 2009 - 02:23 PM
Just engine mounts too go and then I should be back on the road, I am a little worried about the crank tail though.
#414
Posted 02 September 2009 - 06:37 PM
Just can't get the bottom fuse of the fusebox too become live. I can't see where the problem is. I've got the haynes wiring diagram, but for the life of me can't find where the feed from the bottom fuse comes from.
Im realy struggling here, have been tryong too sort it for about 2 hours now.
Ben
#415
Posted 02 September 2009 - 06:43 PM
#416
Posted 02 September 2009 - 10:27 PM
#417
Posted 02 September 2009 - 10:28 PM
#418
Posted 02 September 2009 - 11:09 PM
Ben
#419
Posted 02 September 2009 - 11:28 PM
caliper is up side down. bleed niple is ment to be at the bottom
No it's notthey're all wrong then.
think about it, air will rise. so when fluid comes into the caliper in the middle, the fluid will drop to the bottom, then rise up from there, leaving any trapped air at the top. Bleed nipples should go at the top.
Excactly what I was going too say.Woop I was right
Ben, How do you find it runs with the ride height so low? Do you ever have issues with the tyres scrubbing on the arches over bumps?
I find it ok at this height. I don't have issues with scrubbing even with 3 people and an engine in the boot. I just have the shocks wound up so it's incredibly stiff though. It is too stiff and I have too avoid dips or bumps in the road. I can just about make small speed humps but most of them I have too take at a funny angle too keep 1 wheel on it. It does handle very well aswell. The main problem is that it's so stiff when cornering hard, if I hit a bump the car tends too hop, which completly ruins the cornering. It's not idealy suited for everyday, which is what I use it for.
Interesting about the no scrubbing, what suspension set up is on the rear?? Standard subframe?? What dampers are you running?? Mines low too (looks roughly the same ride height on the rear) and rubbing more than it used to on my arches. Im sure mine are shot as they are years old now, so im looking at new dampers atm.
Shame to see the engines had to come out again! but sounds good atm, fingers crossed for you!! Were the quick release mounts any good??
#420
Posted 03 September 2009 - 12:13 AM
I have GAZ adjustable dampers. Hi los. Standard subframe. Standard rubber doughnuts.
I was out in it just now and I was clipping the cat's eyes, no, im not joking.
I have nothing in the boot. Just a tin of tyre weld.
I have to be honest, it's too stiff. Any bumps in the road cause it too bang and crash along.
Im going too raise it 15-20mm and slacken off the dampers a bit.
Ben
