Lightweight Z18Xe
1943 replies to this topic
#301 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 07 July 2009 - 08:01 PM
Very interested in how this turns out and runs, just starting do do the same down the road in Cardiff.
Some bits will be slightly higher spec'd will have a stage 4 head and run a 45 weber.
Have to meet up at one of the events when both complete to compare and natter
Rofert
Absolutly, are you on any of the welsh forums? some cool people on there.
welshminiclub.co.uk
southwalesminis.co.uk
Luckily with this engine it allows for further modifications, I can drop on a new head, slap on a webber and i've got the cam and capacity below to compliment them. I do plan too add a better head in the future, but at the moment im in my overdraft, and kinda skint, I spend all my money on my mini :lol:
Oh and SFM, yes I do go OTT, I hate oil leaks with a pasion, my car has leaked 1.5 gallons in about 4 weeks.
#302 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 07 July 2009 - 08:05 PM
lol nice
mine used to *yellow human water* outta the dizzy was about 2 liters a month
so used to change it every month lol
#303 mini_mad69
mini_mad69
  • 5,417 posts
Posted 07 July 2009 - 08:22 PM
lol nice
Sounds like too much crankcase preasure.
#304 mini_mad69
mini_mad69
  • 5,417 posts
Posted 07 July 2009 - 10:17 PM
Just priced up my 1380
73.5mm bore block - free
73.5mm powermax pistons free
.10 thou ground crank - free
shell bearings - £40
duplex timing gear - £15
turbo diff/rods - £54
Gearbox - free
MG Metro cylinder head - £40
1.27:1 rockers - free
hif44 - free
Alloy inlet manifold - £28
K&N element - £18
gasket set - £8.71
Head gasket set - £10
seals - £4
Dizzy - free
Kent 286 camshaft free
Sold the head that came with the engine + £26
£192 Total
#305 jaydee
jaydee
  • 8,565 posts
Posted 08 July 2009 - 08:57 AM
Spec of the engine for now will be:
73.5mm bore = 1380cc
powermax dished pistons
turbo rods
.10 machined crank
Kent 286 cam
standard pressed 1.27' rockers
duplex timing gear
Ported MG Metro leaded head v
valve sizes are: Inlet = 1.401"/35.6mm, Exhaust = 1.15"/29.2mm
HIF44 carb
Alloy heated inlet manifold
drilled airbox with K&N element
minisport lCB
Maniflow 1.75" twin box system
3.21 final drive
metro turbo diff
1275 distributor
standard clutch (for now)
It may change but this should be the the spec going in.
Ben
Out of curiosity..why are you fitting spi gearbox and not the 998 one with the 3.44 final drive?
By the way the specs sounds good for either power and reliability.
Edited by jaydee, 08 July 2009 - 09:12 AM.
#306 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 July 2009 - 09:39 AM
It's actualy a metro turbo final drive, on a 998 gearbox. I seem to be doing more and more motorway miles and wanted it to be a bit more livable.
Ben
#307 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 08 July 2009 - 10:12 AM
great work lol your engine builds doesnt seem tooo expensive lol
#308 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 July 2009 - 10:33 AM
I know, but when you think I was given the engine it is quite expensive.
#309 jaydee
jaydee
  • 8,565 posts
Posted 08 July 2009 - 12:06 PM
Ben
Ah ok, thought u were using the gearbox from your 1275. Yes, a 3.2 final drive is better on motorways.
Good luck with the new engine!
#310 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 July 2009 - 02:41 PM
Detailed my tyres, took ages and looks a bit rubbish up close because my paint pen was awfull. Still, I like it.
#311 mini_mad69
mini_mad69
  • 5,417 posts
Posted 10 July 2009 - 10:10 PM
Teeny tiny little bit of an update, not realy worth reading.
last time this will be in here
1380 on box.
1275 out
1380 in
I'll finish it off tomorrow and see if I can get it running.
To say im a happy is the understatment of the century.
Ben
#312 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 11 July 2009 - 11:18 AM
Whheeyyyyyy it's in :P. Can't wait to see this going ;).
P.S. I like the tyres.
#313 mini_mad69
mini_mad69
  • 5,417 posts
Posted 11 July 2009 - 06:37 PM
Cheers andrew, you on facebook?
Ok not happy bunny, it seems my mg head is a bit weird, it sticks on the studs of both engines, took half hour to take it off the SPI.
Engine is pretty much finished, ran into a few problems, mainly not being able to get a lift up to the garage.
Ah well, engine is in. It hasn't started yet, and i got bored, cold and wet so I gave up and came home.
I need a new throttle cable as mine is wrecked and I can't get another one now for about 5 days. I also need a new oil preasure switch as mine broke.
It almost started, im going to have to fiddle with the timing tomorrow as I managed to get a pretty impressive backfire out of the exhaust and carb.hat
Good news is, is that it's holding all it's oil and water without 1 leak as of yet.
Jobs for tomorrow:
Source throttle cable and fit it.
Source and fit oil preasure switch
sort out the timing
get engine running
tune engine
fit breathers, washer bottle and other little bits etc etc
then I'll drain the oil and put fresh oil in and drive it home.
Ben
#314 mini_mad69
mini_mad69
  • 5,417 posts
Posted 12 July 2009 - 04:34 PM
Finally!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! after about 7 or 8 months of work I finally have a working 1380 in my car :thumbsup:
Managed to get a throttle cable, but it's way too short and crap, so too enable to stop it from sticking the cable has to be slack so im only getting around quater to half throttle. SO, I'll order a proper one so I can drive it a bit better, still taking it easy at the moment though. Once i've got it running smoothly and with a proper cable, I'll get a video of taking it for a blast.
Posted ImageJoZxTXj-NXE
A very happy Ben
Edited by mini_mad69, 12 July 2009 - 05:00 PM.
#315 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 12 July 2009 - 05:17 PM
are the pressed steal tappets alot noiser? or is that cause you've fitted a cam ??
