Lightweight Z18Xe
1943 replies to this topic
#1936 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 14 September 2017 - 12:39 PM
Photobucket has ruined this thread as well.
Have you waited a few seconds after the Photobucket notice for the pictures to load?
I have now, have they always loaded after a short while since their new policies?
Unfortunately not, it's a workaround. I won't go off topic, I just didn't want you to abandon the thread. Don't worry about the old images, they will be dealt with along with the rest in good time  =].
Track action looks like a lot of fun! Unfortunate about the clutch. I was just about to say rebuild the slave before remembering you're running a Vauxhall engine.
#1937 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 14 September 2017 - 10:09 PM
Yeah a-series would have been easy. Unfortunately Vaux conversion means Gearbox has to come off. I've got a list as long as my arm of things I want to do, so may do some of them while its out. I think an LSD will transform the car.
#1938 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 15 September 2017 - 08:53 AM
I haven't read your full thread so I don't know if you have power steering. I drove a 2.0l Vauxhall conversion with an Quaife ATB diff and its hard work in the corners under full power. If you've got arms like Popeye you'll have no problem otherwise its something you may want to consider.
#1939 mini_mad69
mini_mad69
  • 5,417 posts
Posted 15 September 2017 - 08:03 PM
Need an LSD
I thought about power steering, but the car doesn't really need it. I only have 100bhp on tap, so it probably won't be too bad. But it is just constantly scrabbling for traction, I can always add a power steering column after if I need too, may need too if I ever get the z18 in.
#1940 mini_mad69
mini_mad69
  • 5,417 posts
Posted 04 November 2017 - 04:54 AM
Next trackday is 2 weeks today. I have not fixed anything. Apart from buying a new battery the car is the same. Need to sort clutch and cooling.
#1941 mini_mad69
mini_mad69
  • 5,417 posts
Posted 13 November 2017 - 06:06 PM
The car overheats quite alot when using it hard on track. I was advised to fit a Polo radiator, but its about 5cm too tall.
You can see the silver Polo radiator has lots of marks on it trying to get it to fit in the front.
The cardboard pictured is the dimensions of a Cinqecento  radiator, which seems the same height as the mini MPI radiator I was using, just about a 3rd longer. It fits in the gap nicely, so i've ordered one of them.
I rebuilt my clutch master cylinder as well. The old seals seemed ok, and it was only when on track that the issues appeared. So Saturday will be the test.
#1942 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 01 November 2020 - 09:19 PM
Is it finished yet?
#1943 mini_mad69
mini_mad69
  • 5,417 posts
Posted 31 May 2021 - 05:37 PM
Yeah
#1944 Mini-Mad-Craig
Posted 02 June 2021 - 02:46 AM
floating away on a custard cream
