Lightweight Z18Xe
1943 replies to this topic
#1921 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 19 April 2016 - 02:54 PM
Give it to malcolm so he can pull it to bits and abandon it somewhere. You know like he did with the last one?.
Then get an M3
#1922 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 19 April 2016 - 02:56 PM
Ok fine.
#1923 mini_mad69
mini_mad69
  • 5,417 posts
Posted 19 April 2016 - 03:01 PM
Turbo is now on and working well!!
AWD drive next
#1924 HARBER07
HARBER07
  • 4,498 posts
Posted 19 April 2016 - 03:06 PM
How much boost you running bro??
#1925 mini_mad69
mini_mad69
  • 5,417 posts
Posted 20 April 2016 - 08:18 PM
37psi
#1926 MotorBoatMyGoat
MotorBoatMyGoat
  • 33 posts
Posted 22 April 2016 - 12:11 PM
Hi. Is the 1.8 sri engine? Is it a standard size front end or extended? Cheers
#1927 mini_mad69
mini_mad69
  • 5,417 posts
Posted 22 April 2016 - 07:38 PM
Currently has the e16se Nova GTE engine.
The z18xe is the Corsa SRI 1.8 I think. I have two engines ready to drop in. One out of a Vectra 1.8 and one from a Bertone astra coupe.
I'll be doing the switch when i get back from Newquay with it.
Standard size front.
#1928 J960mayfair
J960mayfair
  • 267 posts
Posted 31 May 2016 - 04:45 PM
have you seen that series on youtube they are building awd so much fabrication its crazy!
#1929 mini_mad69
mini_mad69
  • 5,417 posts
Posted 11 August 2016 - 11:34 PM
Lol
#1930 HARBER07
HARBER07
  • 4,498 posts
Posted 27 September 2016 - 08:39 AM
Finished yet?
#1931 mini_mad69
mini_mad69
  • 5,417 posts
Posted 27 September 2016 - 04:44 PM
Been buying / deciding on stuff..
Clubman front will go on to accommodate proper sized radiator, bigger engine, and turbo.
Got a exhaust flange on order to make a log manifold for the td04L with a certain north Wales tall fella.
#1932 mini_mad69
mini_mad69
  • 5,417 posts
Posted 06 July 2017 - 12:24 AM
Photobucket has ruined this thread
Then get an M3
Ok, now what?
Anyway....
Been a little distracted from the mini recently with Binis, MX5s and now an M3.
The turbo I bought for this car made its way onto an MX5, which blew up twice, however, the turbo, interooler, wideband, boost controller can all be transferred onto the mini.
All I'll need to do it make a manifold and downpipe for it. And get hold of some sort of management. I may bolt it all onto the e16se or drag one of Z18xe engines into the front. Not sure yet, probably the e16se to start with.
#1933 HARBER07
HARBER07
  • 4,498 posts
Posted 12 September 2017 - 07:52 PM
Also boost the M3.
Photobucket has ruined this thread as well.
#1934 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 13 September 2017 - 02:19 PM
Have you waited a few seconds after the Photobucket notice for the pictures to load?
#1935 mini_mad69
mini_mad69
  • 5,417 posts
Posted 14 September 2017 - 11:25 AM
I have now, have they always loaded after a short while since their new policies?
Rolled the mini out, no pictures. Still off the road but loaded it onto a trailer to take to my local track for a  trackday.
Quick video, but had a few issues:
Brakes were sticking.
It was sliding all over the place. (fun but not fast)
Engine over heating.
And then around lunch time the clutch failed. I actually carried on for around 10 minutes without a clutch, the lightened flywheel makes it surprisingly easy. It was getting air in the system. Not sure if it was the slave or master, but I'll change both. The clutch master is 32 years old!!
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
