Lightweight Z18Xe
1943 replies to this topic
#1906 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 26 March 2015 - 11:20 PM
My lightweight doors are really really really light. But I work at an airport and need to open and close the window to access the barriers to get in and out. And I fancy adding a bit of soundproofing to the car.
E8C34EDE-CB9C-4B11-A35A-B9C30E5017ED_zps
Bought some doors.
6EC8AD9D-389B-4346-94ED-9925DC773629_zps
Took the skins off.
29DA8A7E-6E66-41A5-9806-219E37A708DE_zps
Frames were a bit crusty.
62889BE0-2755-4FBC-A61E-8D5F00104A62_zps
New metal.
DBBD73A1-C212-44C6-B515-08BA9E124255_zps
Skins got some sound proofing.
EE0FB387-8E87-4730-AAAE-DCFE2F0A778B_zps
New skins on!
They weigh a tonne, even not built up with winders and glass etc But i think it'll be worth it to have the car more usable.
Edited by mini_mad69, 26 March 2015 - 11:39 PM.
#1907 mini_mad69
mini_mad69
  • 5,417 posts
Posted 06 April 2015 - 08:16 PM
Drove it the other day, missed driving it. Running fine since the head gasket. The alternator light wasn't working properly when i finished, but I think that might just be a loose wire.
0695DCF0-4FCC-49AE-9CDD-6A66B01D3E89_zps
Took a door off..
3DB6B81F-9552-4650-A79C-DD6B53D6891A_zps
Put a door on.
Couldn't believe it fitted first time. No adjustment what so ever.
10DD80B0-C46A-4954-856C-B9D0CEE002CD_zps
I was given some dooor panels, think I'll try dye them black.
The nearside door took alot more work to make fit. I had to cut the bottom off and git a replacement panel, and it was cracked all over by the hinges. No pictures of that though.
096A8FB7-DCAC-42AF-A5B2-254832F16B3F_zps
So Primed the doors.
Hopefully get this sorted and maybe take it to riv run.
Or take my Bini, havn't decided yet.
#1908 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 April 2015 - 08:00 PM
D3CEE6B4-6E27-4CBC-A1F4-601E47199A27_zps
Got some colour on the doors.
#1909 mini_mad69
mini_mad69
  • 5,417 posts
Posted 12 April 2015 - 07:30 PM
072B5224-CD29-4554-A294-C00FFC659D28_zps
50D6DFBC-7E77-41AB-AC10-DEE5A5083A4F_zps
2EF73988-4843-40A8-805E-B6DA3785248B_zps
Annoyingly the doors have come out alot better than the rest of the car. So it will need a good flat and mop to try and make it better.
27BBA51C-E4F7-4FC2-9D06-03EA6D884137_zps
Anyone interested in these?
#1910 mini_mad69
mini_mad69
  • 5,417 posts
Posted 13 May 2015 - 08:48 PM
D51F0009-CCAB-4B5C-A287-70AFE89182D9_zps
Welded on some brackets
FFA3AD33-A7B3-45D0-ADEC-B24854543A04_zps
Primed
EABF1B76-C96D-4997-B952-76035BD9EB9C_zps
Painted same colour as the roof.
C40C735E-990C-4486-8530-AEF588108353_zps
EDDB1E87-A753-40C2-A557-2CD413DD6B23_zps
6440A83F-39A7-4FA1-B13B-40566C06D623_zps
This stuff is great!!
169718DB-F9C8-40DB-8C83-2D8723C9F3DF_zps
Came out ok.
8DF3D313-EBBA-4678-A1FF-841523D14D3F_zps
Grill came off 6 months ago on the trackday.
3C668095-8F35-498B-9C21-0188D8BD57B6_zps
Put it back on.
5D190990-0888-45C9-BCA2-AA3FEAC982B4_zps
BA028773-9E52-4FAA-B5C2-B44AA1AFDACD_zps
Also bought this.
I've sold my daily driver Bini, so this is being put into full time use for a few weeks. So will be making is more usable with an interior and sound proofing. Need a radio though. getting boring on my commute.
#1911 mini_mad69
mini_mad69
  • 5,417 posts
Posted 11 August 2015 - 09:33 PM
11825232_10153031730608309_5366879637294
Rollcage came out ok, same colour as roof.
11825227_10153031730658309_2702581304449
The paint has never been very good on the car, looks alot better in pictures than it is. You can see in this picture near the vertical seam where the rear quater and rear panel meet.
11822645_10153031730238309_5054076497095
So decided to wet sand and mop some parts of it. It came out a bit better. But Ideally parts of the paint need to be re-done.
11863432_10153031730088309_7638854853368
A little better.
11058617_10153031729978309_1355813901850
Rear cage painted and installed. I also fitted a load of sound deadener and some carpet to the back. I know I need to buy a headlinder. Need to sort out some water ingress issues at the front and re-inforce the front floor at lower subframe mounts as it's gotten damaged. But been using the car a lot more recently and nothing serious to report. Just going to make it a but more comfortable, tidy some things up and get the NOS on it.
11826010_10153031730423309_2412493614984
#1912 mini_mad69
mini_mad69
  • 5,417 posts
Posted 22 January 2016 - 12:01 AM
Never got round to sorting the NOS out and sold it on.
Got another trackday on Saturday so been doing a few bits.
BE830A86-7CC3-4235-8F51-F5DA6003C985_zps
Had a few issues, one being the loom catching on fire for no apparent reason today, so i'll have to sort that tomorrow, the main feed from the solenoid to the ignition switch went up, and I can't work out why. Ran a new wire to test and it worked fine. I'll fit a master kill switch tomorrow.
15EE2AB2-865B-4E0F-A118-763D8042FE00_zps
Boot paint has gone weird.
The subframe ripped a 6 inch crack in the drivers side floor plan.
A51A9D4A-F086-4B88-809A-00B4D04CE38B_zps
So Fitted some 2mm steel plate, welded in now.
884A8709-34D5-4638-BC8D-48F518366D1E_zps
List not really moving.
B482E490-9B44-4041-98AC-E7F5F6F8AF45_zps
Never really mounted my radiator properly, so knocked up a couple of quick brackets to hold it steady, another temporary fix that will more than likely be permanent.
655FD9DC-AE75-4202-81EB-DCD9E77796AF_zps
Picked up a set of 13x7 with very good Dunlop sport tyres on very cheap locally.
FD1D67AE-89A4-4409-82F8-55955D0609A7_zps
Fitted some death pads, worked on my Bini ok, so thought I'd try them on this.
Still loooooooooods to do tomorrow, and hopefully it doesn't catch fire again.
#1913 mini_mad69
mini_mad69
  • 5,417 posts
Posted 26 January 2016 - 05:02 PM
Car got warm after around 15 mins and developed a misfire, let it cool down and it was fine. Did find a loose HT lead at the end of the day.
#1914 mini_mad69
mini_mad69
  • 5,417 posts
Posted 17 March 2016 - 12:20 AM
12828987_10153425740588309_6334172025819
Doing stuff.
#1915 mini_mad69
mini_mad69
  • 5,417 posts
Posted 07 April 2016 - 10:49 PM
CB15840D-94BB-49CE-B05E-C9D351AE1262_zps
DCF20D51-AA68-456D-B06C-0E7B012009B8_zps
Trying to get a bigger radiator on it.
D73701C5-B6F7-4881-82BB-E104C78C9811_zps
I'm taking it to Newquay for Riv Run at the end of the month, there wasn't really anything wrong with it. So I took the engine out.
#1916 mini_mad69
mini_mad69
  • 5,417 posts
Posted 17 April 2016 - 09:12 PM
645450B6-864C-4470-95CE-DE1B647F66EE_zps
I pulled out my race fuel tank as i was getting annoyed with not having any boot space. As i'm going to Newquay in it soon for Riv Run, I want to be able to take some luggage and tools etc. So decided an MPI tank would be the best option. I found my vectra pump and little low pressure pump way too noisy as well on the previous setup. I need to sort the boot floor out, as the second hand carbon one in there is in a terrible state.
#1917 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 19 April 2016 - 02:47 PM
Gay
#1918 mini_mad69
mini_mad69
  • 5,417 posts
I'm Gay
I know
Edited by mini_mad69, 19 April 2016 - 02:48 PM.
#1919 HARBER07
HARBER07
  • 4,498 posts
Posted 19 April 2016 - 02:49 PM
You should get another mini.
#1920 mini_mad69
mini_mad69
  • 5,417 posts
Posted 19 April 2016 - 02:51 PM
Ok...................
C36251D4-F899-4324-9E02-081378A78C94_zps
Now what?
