Lightweight Z18Xe
1943 replies to this topic
#1891 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 19 January 2015 - 08:54 PM
Did the same on my astra 4 years ago. On the plus side I expect one of your cylinders will be nice and clean.
Swapped the gasket and its been ok since.
It's still running ok-ish. So I suspect a new gasket and its probably ok.
Alllthhhoooouuughghgghhgh.
I may have a DTA ecu on the way to me, so If I can get hold of some bottle throddies I could drop the z18 in.
That's be nice.
#1892 alexcrosse
alexcrosse
  • 3,786 posts
Posted 20 January 2015 - 07:54 AM
It would be nice. You should totes weigh that Z18 too.
#1893 mini_mad69
mini_mad69
  • 5,417 posts
Posted 21 January 2015 - 11:12 PM
I'll see if i can weigh it, need to find a set if scales that arn't glass first.
3379E314-8DD0-469D-8F07-6C55188FDAD7_zps
C8CAAA87-0C20-4BD5-AAC9-38F95657669C_zps
[URL=http://s302.photobuc...sdzv2.jpg.html]689B1B5F-D9A4-41A8-9469-596B38B36730_zps[/URL
Got all this soundproofing to fit as well.
#1894 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 22 January 2015 - 08:18 AM
What's that mirror for? Is it a vanity ting or a learner driver ting?
#1895 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 22 January 2015 - 08:19 AM
Dammit, I was going to put a banana in with the DTA when I sent it, totes forgot! >_<
#1896 alexcrosse
alexcrosse
  • 3,786 posts
Posted 22 January 2015 - 08:56 AM
Just put wood on the scales? then weigh the wood. Doesn't weight more than a person :)
#1897 Tomm
Tomm
  • 2,462 posts
Posted 23 January 2015 - 09:17 PM
Those boradway mirrors are so good on track days. They are also hugley helpful when driving abroad as well.
#1898 mini_mad69
mini_mad69
  • 5,417 posts
Posted 29 January 2015 - 10:41 PM
The scales are at my mothers, she'd freak. I may have some more somewhere, I'll check. Still don't know why you need me to weigh one though.
This car hasn't gone 5 miles outside my town since I've done the conversion. Abroad doesn't really come into it. Unless you count England.
Vanity.
#1899 mini_mad69
mini_mad69
  • 5,417 posts
Posted 22 February 2015 - 06:49 PM
A little while ago, I stuck a new alternator belt on the car after it threw it off on the trackday. I then started to make progress on making it more useable and stated to fit an interior.
Took it for a spin to get a before reading of decibels before I fitted all my sound proofing. It overheated, and puffs of blue smoke occasionally appeared behind me.
When i got it back I checked the coolant and it was bone dry. no idea why. There was no evidence of any leaks anywhere and the engine hadn't appeard to have burnt any.
Anyway, did a compression test and 1 and 2 were down on compression. Took the head off, and the gasket appeared to be ok, but had the head skimmed and bolted it back on with a new gasket and bolts today. Done another compression test and again. Cylinders 1 and 2 are still down on compression.
Don't know what to do now, got a feeling the engine could be dead now.
I've got a DTA ecu here, and a Z18xe engine sitting in my shed. So may give up on the e16se and drop the z18xe in. Just need an inlet system, (Jenveys on manifold or similar) and an exhaust manifold. Or I could turn my botched up manifold I was going to put bike carbs on and try make a log manifold?
#1900 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 02 March 2015 - 09:24 PM
Finished yet?
#1901 mini_mad69
mini_mad69
  • 5,417 posts
Posted 03 March 2015 - 11:27 PM
Yeah man. Its quicker again.
#1902 mini_mad69
mini_mad69
  • 5,417 posts
Posted 17 March 2015 - 10:12 PM
Bolted it back together after loads of issues and the most expensive o-rings i've ever seen and its running ok. Will test drive on the weekend.
Edited by mini_mad69, 17 March 2015 - 10:13 PM.
#1903 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 18 March 2015 - 07:15 AM
That is well sick! You gonna pop to RRG in it?
#1904 alexcrosse
alexcrosse
  • 3,786 posts
Posted 18 March 2015 - 08:19 AM
So what were the issues?
And why did you spend so much on O rings?...
#1905 mini_mad69
mini_mad69
  • 5,417 posts
Posted 18 March 2015 - 11:01 AM
Might go rrg in it. No idea what issues were, but with a skimmed head and new gasket its running again. It was still down on compresion when i tested it. But its still running fine.
Its got vaccuum leaks everywhere, i fitted a water temp gauge on the back of the engine, when thats reading around 90 degress, the gauge i had before still isn't moving off the stop. Sooooooooo it was probably running pretty hot before.
O rings were injector seals, bought from vauxhall. Bare money.
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
