Got any pics of how you fitted the aero catches like that? Not seen them fitted there before.
Lightweight Z18Xe
#1846
Posted 28 April 2014 - 10:34 AM
#1847
Posted 28 April 2014 - 09:08 PM
They do have a slot in the side for the pins to fit through as well
#1848
Sorry forgot to get a pic. Basicly there is a small bracket welded to the inside of the a-panel which has the pin running into the side of aero catch.
#1849
Posted 29 April 2014 - 11:01 PM
#1850
Posted 30 April 2014 - 10:42 PM
#1851
Posted 08 May 2014 - 09:11 PM
New windscreen arrived from mini spares.
Both fitted with new rubbbers.
Got the rear engine mount from allspeed and got it fitted, however, as I shimmed up the rear of the engine up to try and clear the master cylinder, it wouldnt fit the rear mount brackets. So fitted one of the land rover mounts I had from earlier in the build. Which works just right and keeps the inlet manifold from the masters. I got someone to sit in the car and bring the clutch up to the bite quite hard and the engine doesnt seem to catch them. It is very close though.
Need some wider arches and a tyre and I've got most of the bits to make it legal.
#1852
Posted 10 May 2014 - 11:53 PM
#1853
Posted 16 May 2014 - 10:37 PM
number plate on
ride height way to high
Used belts to hold down bonnet at front.
Took it for MOT and it passed!!!!!!! few advisories i need to sort out and defiantly only just legal.
It blew off a coolant hose.
And drove it back.
Took it out again wednesday and it blew its water out of the expansion tank.
Needs paint
Still finding loads of issues.
Gear linkage being one of them. Struggling to find all of the gears. and in a horrible position
Rear arms bottoming out.
Hideous traction issues.
Needs a dashboard
Needs paint
Need wider arches
need a longer gearbox ratio
Adjust seats
Exhaust rattles
Locks don't seem to work reliably
re-attach washer jets ( they fell out)
Work out how to bleed coolant system better.
But it goes like hell to around 70mph.
best 0-60 time i've had so far is 6.9 seconds but it wheel spins to the end of second gear.
Will have it out to play on the weekend and get some vids of it driving.
Edited by mini_mad69, 16 May 2014 - 10:48 PM.
#1854
Posted 16 May 2014 - 11:58 PM
Spinning one wheel, or both?
If it's just one, some of this can be adjusted out using the hilos.
#1855
Posted 18 May 2014 - 06:36 PM
Spins both, or whichever one has the least grip. Doesn't seem to favour one in particular. Theres quite a bit that needs sorting before I make any judgments on how it drives or handles yet.
#1856
Posted 19 May 2014 - 08:22 AM
Fantastic top stuff! It's really come together over the last month or so, really tell you've put the hours in.
#1857
Posted 19 May 2014 - 07:16 PM
Before RIv I had the week off and worked hard to try and get it there. But since then its been a few weekends. But yeah, done more work in the last month than the last 6 months.
#1858
Posted 21 May 2014 - 03:05 PM
I have just read your whole thread from start to finish and am jealous of your skill and dedication!
I now want to convert mine to something more powerful!
#1859
Posted 21 May 2014 - 05:42 PM
Absolutely amazing.
Thanks.
Yeah, the a-series is all well and good, but if you're looking for a faster mini with still some reliablity and not break the bank. A conversion in my eyes is the way to go.
Especially this one using the allspeed frame. Engine just bolts in and only a couple of wires to make it work.
#1860
Posted 21 May 2014 - 09:57 PM
